[C2] Need quick info on L71 belt numbers
Old Today | 07:37 PM
ettev's Avatar
ettev
Default Need quick info on L71 belt numbers
Looking for all correct replacement belt part numbers (preferably AC Delco) for a ‘67 L71 car….with power steering. Getting conflicting info from different vendor webpages.
Old Today | 07:41 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Quanta products who supply the "correct" style belts often makes two correct length belts for repro and original pulley configurations.
Old Today | 08:39 PM
ettev's Avatar
ettev
Thanks Keith
Old Today | 10:08 PM
Powershift's Avatar
Powershift
What do the old belts say regarding their size/length?? Should be marked.......... or NAPA or others should have a belt sizing tool that can measure the old belts. Worst case is no belts to measure. Then buy a cheap one from hardware store that is longer than needed. Cut it. Wrap around the pulleys and mark where the ends overlap. Measure the length. That is your size. Make sure you also have the correct width to go along with the length.
Or you can check the Chevrolet Parts Manuals to gets what sizes GM recommends. They may or may not fit depending on if you have engine/pulley revisions from OEM.
Larry
To Need quick info on L71 belt numbers
