Drain Plug snapped. Extracted it and helicoil came out
As the title states, I had a rather unfortunate discovery on my C7.
I've done the past few oil changes on the car myself with no issues and I tend to torque it with a torque wrench but set to 25ft-lb. At around 20ft-lb, the torque wrench started to spin super easy and unfortunately the drain plug broke. How unfortunate.
I spent an hour or two extracting the bolt as it was quite difficult but I was able to get it out. However, I noticed at the end of the thread there was this metal spiral hanging out. I just assumed it was from the broken bolt so I decided to pull it out and it was *not* a part of the drain bolt.
I discovered that the previous owner must've inserted had the pan retapped and placed a helicoil in there to retain the OEM M12x1.75 sizing.
Not really sure what my best options are here.
Should I try to place in a new m12x1.75 wire thread in the hole or try a M14x1.5 oversized drain plug.
This is on my built C7 Z51 with an A&A supercharger (side note, been over 30,000km since supercharger install and ZERO issues except this drain plug so).
Any help would be greatly appreciated.
re-insert a new coil. Break tang, rinse tang out of oil pan. Done
Edit: you're also overtorquing the plug. 18ft lbs is the OE torque spec. Torque wrenches generally aren't considered accurate at the low and upper end of their scales, so if your wrench bottoms out at 25ft/lbs- you're really putting the beans on a small, ungraded bolt
based on the condition of the head of the bolt, it's been overtorqued a lot in the past too
Regarding the ft-lb, I made a mistake. I had it set to 25nm (Canadian sorry) on the torque wrench which is 18 ft-lb, just a mistake in the thread. But you are right about the bolt definitely being over torqued in the past. I know the mechanic shop I took it to that built it took the plug on and off multiple times and I don't believe they ever replaced it.
Would using this kit be sufficient to place the new threaded coil into the hole? I won't be using the taps or anything as I don't believe I need to tap the hole at all, just placing a new coil in.
Otherwise, I may attempt to do the oversized oil drain plug and if that does not work, it looks like my cheap repair will no longer be a cheap repair
Just how do you expect to remove the 'break off' tab from the installed pan?
And I'd use a longer Helicoil.
https://www.timesert.com/
Its called a tang, and you can rinse it out with oil. You can also put a glob of grease on the tool to capture the tang when you snap the tang off. This is a very simple repair. I would not chase threads unless the lead thread of the pan has been damaged. You don't want to open up the minor or major diameter as the wire needs to be an interference fit in the pan
Timesert is absolutely a better repair, but based on what I have seen in this thread, the skill level necessitates just reinserting a helicoil and snapping the tang off. And even that process seems to be flying over some heads
People on Facebook are recommending to retap before placing the helicoil but I think I'm just going to clean the threads well first with a light wire brush before considering retapping.
First time doing this, but we're also farmers so I don't think it's too daunting. Hell, I'm actively considering learning how to drop the pan if needed but I do know it will take me 6+ hours to do on my spare time.
Considering that the last person has messed up the threads, I'd feel better about chasing the threads to make sure. Afterwards, install a drain valve so you don't have to keep taking the plug in and out.
My leading theory right now is that when I originally removed the drain plug, the helicoil (factory or aftermarket) came out slightly and when I went to reinsert the bolt, the end of the helicoil put pressure on the bolt head and caused it to snap. That's why in the first photo, you can see the broken bolt in the oil drain plug with the helicoil pointing out slightly.
I will know later today if inserting the new helicoil is sufficient and I will be placing a drain plug on it so I don't have to deal with this issue going forward.
