Alternator voltage fluctuation
Old Jun 4, 2026 | 08:56 AM
JKNAPP's Avatar
JKNAPP
Default Alternator voltage fluctuation
Been chasing an intermittent voltage issue on my Z06. Alternator voltage drops to like 12.3 when idling (hot) but then generally jumps back into the 13's while driving? checked all connections and a couple tightened up a little...but didn't change anything overall . Alternator seems to test out fine (load test), so what should I look for next?
Old Jun 4, 2026 | 01:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
How exactly did you perform this alternator "load test" ??...normally for voltage issues like this we do a voltage drop check of the charging system from the battery to the alternator using a DMM...you must do a little more than "checking the connections"...they must be tested.
Old Jun 4, 2026 | 02:06 PM
JKNAPP's Avatar
JKNAPP
I'm definitely not great with electronics, we basically just monitored output increases upon load requirements. It only happens when the car gets hot...?
Old Jun 4, 2026 | 02:11 PM
C5 Diag's Avatar
C5 Diag
You may have to have some "skills" to diagnose this...with heat comes resistance and with resistance comes a voltage drop...voltage drop testing is easy and you should also be checking the alternator voltage AT the alternator...the B+ cable at the alternator goes to the starter solenoid and at the starter solenoid is the battery B+ cable...if the connection is poor there you will have a voltage drop...was that checked ??...you need to get under the car.
Old Jun 4, 2026 | 02:43 PM
JKNAPP's Avatar
JKNAPP
https://youtu.be/vciL8qXVe2k?si=p7D033AKNFH7Fb4V
Has not yet no, will check on my next day off. Appreciate.
Old Jun 5, 2026 | 03:10 PM
on track's Avatar
on track
Is it an aftermarket alternator? Do you have an underdrive pulley installed?
Old Jun 5, 2026 | 04:21 PM
JKNAPP's Avatar
JKNAPP
Was on the car when I bought it...it is chrome so? regular diam balancer.
Old Jun 5, 2026 | 09:24 PM
on track's Avatar
on track
I'd swap the alternator with a known good factory unit.
Old Yesterday | 07:17 AM
JKNAPP's Avatar
JKNAPP
Doing some testing now, but I will put a Mechman on it soon I'm sure
To Alternator voltage fluctuation
