Fan turning on at 190F
Old Yesterday | 05:14 PM
Cor29's Avatar
Cor29
Default Fan turning on at 190F
Noticed my coolant temps dont go above 190 amd thats where the fans go on.
Thought they were supposed to turn on at 220F
Old Yesterday | 05:22 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
There are two fans. Under normal operation, they come on at different temps. However, it is possible to change that with a tune. Both of mine turn on at 199, but it's got an aftermarket tune. My guess is you have something similar going on. It's not a bad thing.
Old Yesterday | 05:23 PM
Cor29's Avatar
Cor29
So my car is possibly tuned? With just a cai?
Old Yesterday | 05:24 PM
LegionnaireCM's Avatar
LegionnaireCM
Sounds like you've got a good mechanic. I'll take 190 over 220.
Old Yesterday | 05:40 PM
MWWarlord's Avatar
MWWarlord
It's a pretty basic setting change to make. It doesn't necessarily mean there were major changes made to the fuel mapping or anything. As long as the car is running well, I wouldn't be too concerned. It's good to be aware of it though.
Old Today | 07:16 AM
Trickskier's Avatar
Trickskier
My fans turn on at 190* if I have my AC on.
Old Today | 08:05 AM
Cor29's Avatar
Cor29
my ac doesn't work cause the ac button flashes when i turn it on and then shuts off.
Old Today | 09:52 AM
the_merv's Avatar
the_merv
I Tuned my Z06 and set the Fans to come on at 195 Low 205 High. AC turns the Fans on High instantly below 35mph. That's a factory setting.
Sounds like there's an issue if your AC is not kicking on, might be one of the Pressure Sensors out.
Old Today | 09:53 AM
Cor29's Avatar
Cor29
or no freon.
Old Today | 10:06 AM
the_merv's Avatar
the_merv
Yup that too. You watch to see if the AC Clutch is kicking on?
Old Today | 10:47 AM
MWWarlord's Avatar
MWWarlord
Old Today | 12:12 PM
Cor29's Avatar
Cor29
Originally Posted by MWWarlord
the ac is another issue altogether. May be low on freon will get it checked. As for the fan kicking in at 190...its out of curiosity as to why.
Old Today | 12:18 PM
the_merv's Avatar
the_merv
Factory setting is over 220 Low Speed, so yeah it may have been tuned like several of us have said.
Old Today | 12:19 PM
Cor29's Avatar
Cor29
is there a way to verify that?
Old Today | 01:40 PM
the_merv's Avatar
the_merv
Scanner on the car to see actual temp and when the Fans are commanded on.
Old Today | 01:44 PM
Cor29's Avatar
Cor29
ill use my obd2 Bluetooth dongle with in car doc app or torque app and see.
To Fan turning on at 190F
