[C2] Stereo problem
Old Yesterday | 10:20 PM
pippa's Avatar
pippa
Default Stereo problem
I’m trying to put a custom audio sound 630 in my 64 coupe. The problem is the stereo works fine when the engine is off when I. Start it up the stereo brakes up.what could be causing this
Old Yesterday | 10:29 PM
acstephenson's Avatar
acstephenson
You need to define "brakes up". Does that mean it shuts off and back on or static or noise? Crackling noise or whine? AM? FM? Other? Did this car originally have a radio and did it work?
Old Yesterday | 10:49 PM
c2vettehead's Avatar
c2vettehead
Probably a ground issue.
Am fm as bad as Bluetooth sources?
Old Yesterday | 10:51 PM
c2vettehead
BTW, you probably mean "breaks up.“
Old Today | 11:15 AM
pippa's Avatar
pippa
It comes on & off real fast.
Old Today | 11:20 AM
pippa's Avatar
pippa
What I mean by breaking up is it plays good & then it cuts out &then back on real fast
Old Today | 11:32 AM
Factoid's Avatar
Factoid
Is your alternator working properly? What is the voltage at the battery both with the engine off and then running?
Old Today | 11:52 AM
acstephenson
That probably means your charging system is very noisy (many voltage spikes and unstable voltage). It could mean that eventhough the average voltage is normal (~ 14 volts) that the instantaneous voltage is all over the place so that a voltmeter may not tell you all that much. Noisy output is common with the old vibrating points voltage regulator that was original to your car and to take some of that noise out, Chevy added capaicitors to the regulator. Check to see if that capacitor is still on the regulator. If you are very lucky, it could be something as simple as a loose fan belt or poor ground connections at the alternator, the battery, the regulator, and your audio unit. Unlike other cars with metal bodies, Corvettes are very sensitive to ground connections. You should also make sure the main output connection at the alternator is tight as well as other power connections. You might try adding a fairly large capacitor just before the unit's power connection.
Old Today | 03:25 PM
lucky131969's Avatar
lucky131969
Let's simplify the language here.
Do you have a loss of power problem, where the whole unit losses power temporarily, and then turns back on ...............OR.......
do you have an audio problem, where the unit remains powered but the sound is heard at a set volume, shuts off, then back on?
To Stereo problem
