I just bought an Aeroforce gauge and got it installed. I also recently installed a supercharger so I wanted to initially display boost and fuel pressure. I know these gauges are displaying what the PCM sees. It was strange to me that the fuel rail pressure parameter is displaying a negative number. Anybody on here have any experience with these parameters that might help me understand what that number means, what it should be and what values would indicate a problem?
Not too familiar on the Aeroforce gauge but the factory never had a fuel pressure parameter to read so not sure how it would be reading rail pressure from the ECU since there is no fuel pressure sending unitt. One would have to install a fuel pressure sending unit and tap into that to read it.
Boost would need to be tapped into the vacuum line that the blow-off valve uses.
I went with the P3 Gauge as it it looks "factory" as it doesn't require a pillar gauge pod. I get boost, Air/Fuel ratio with my 02 sensor, EGT, IAT, plus all the other factory readouts (oil pressure, coolant, oil temp). Plus it logs the highest readouts
Interesting.
My tuner asked me to change out my MAP sensor so we could get a boost reading to the computer so that is covered. I installed a 3 bar sensor, same as a ZR1 uses so that covers me on the boost. I would have thought the computer would see fuel pressure but I guess not. Curious that I am even getting a number at all.
The reason I would like to see fuel pressure is to make sure the boost a pump is coming on like it is supposed to and keeping everything good. I wonder if the air fuel ratio would be an indicator of that or maybe some other parameter?
Interesting.
The fuel pressure number is probably just a random parameter it is showing as a default since the ECU never had a fuel pressure reading. I asked the same question when I installed my P3 gauge, and the answer was the C6 ECU does not have a fuel pressure readout. In CLOSED LOOP scenarios (cruising/part throttle), the ECU monitors the factory 02's to determine air/fuel ratio. While in OPEN LOOP during a WOT pull, the ECU goes back to what the tuner did and runs the fuel parameters off the tune they did. Most tuners will run the mixture a little rich with a supercharger as they don't want to run the risk of running lean and hurting the engine. You might lose a few HP by running a little rich but better than hurting the engine by going lean at WOT.
I use the air/fuel ratio monitor on my P3 gauge as a source to make sure the boost-a-pump is functioning and the engine is not leaning out during WOT. Best to have a video camera or a passenger watch the gauge during WOT as the driver should be watching the road and not the gauge during a pull.
If the 02 showed a lean condition then that means something is amiss and the engine is not getting enough fuel.
A standard mechanical boost gauge would need a vacuum/boost hose connected to it, but an electronic gauge can read boost via your MAP sensor. MAP minus BARO equals Boost and this is how my scanner is set up to log boost without a mechanical gauge.
Pettrix is correct on the car lacking a fuel pressure sensor from the factory. To read fuel pressure you would need to add an aftermarket sensor and wire it to your gauge if it can handle separate inputs and not just CANBUS inputs.
Short of a dedicated fuel pressure gauge, the A/F gauge will tell you if you have enough fuel supply. If your boost a pump failed it would show too lean under boost.
That's really dependent on your tune, but I shoot for around 11.5:1 under boost. Assuming your car is tuned properly, you would be looking for the actual AFR to match your commanded AFR in your PE table.
Thanks for your replies. I am certainly not familiar with the A/F readings so what would generally be considered a good A/F ratio versus a bad?
Under WOT, you should be in the 11.2 to 11.7 range for pump gas. While shifting the numbers will jump up/down for a brief second. During normal cruise/idle and not under boost, then 14.5 to 15.0 range
You don't want to see 12.0 or higher under boost at WOT, as that means it's too lean and will be detonating. Under 11.0, then it is getting too rich, which won't hurt anything except you will lose some HP.
I ALWAYS recommend running a quality oil catch can like Improved Racing/Mighty Mouse, etc when running boost in a LS3. Oil vapors have an octane rating of 48 and they will be introduced into the combustion chamber, which then lowers your octane rating to lower numbers and you can detonate from that.
Trap the vapors in a catch can and it will keep your octane rating high and it will also keep your intake from getting oil deposits.
This is good information. Thanks so much. I also plan to use the graphing function on the gauge so I can see how it behaves under different conditions. That way I can build a history of the range.
Well, I tried using the air fuel parameter on the gauge and got no reading. I looked up parameter descriptions in the gauge manual and it says the A/F readings will only display if you have a wideband factory sensor so I guess the Corvettes don't have these. So now I cannot monitor the air fuel ratio either....
Kind of amazing to me that a high performance car does not have this kind of sensor. The PCM has to know what the air fuel ratio is, surely it is not some sort of calculated number.
You can install a fuel pressure sensor on the driver’s side fuel rail and run the wire into the car under the dead pedal. Does require drilling a hole. Aeroforce sells the sensor.
The LS3 has four 02 sensors but you CAN'T get readouts of those with your gauges. One has to install a wideband 02 sensor BEFORE the cats to get a proper tuning readout during WOT.
Two Upstream 02 Sensors: Located before the catalytic converters. They monitor the exhaust and adjust the engine's air-fuel ratio.
Two Downstream 02 Sensors: Located after the catalytic converters. They monitor the efficiency of the cats themselves
The factory 02s read the air/fuel mixture before and after the cats and adjust as needed during part throttle or cruise. Once you go WOT, the factory ECU stops reading the 02s and goes by whatever the ECU was programmed by the tuner.
So the ECU does read the factory 02s but only when part throttle or lower. 3/4 or WOT, the 02s don't matter as computer goes by whoever programmed the tune.
Who tuned your setup? They should have drilled and tapped a bung BEFORE the cat (usually on drivers side) to do the tune. If they did, you can unscrew the cap and install a wide band 02. That's the way I have my setup...
