Drivers-side B-Pillar Creak Noise
Old Today | 01:40 PM
Pettrix's Avatar
Pettrix
Default Drivers-side B-Pillar Creak Noise
When driving I notice a noise coming from the B-Pillar from where the seat belt attaches to. It's not coming from the targa top but from that plastic pillar just behind the drivers-seat.
Any solutions on how to quiet that?
Old Today | 03:49 PM
Konadog06's Avatar
Konadog06
Default Creak noise
This is where I found mine.
On the side with the noise look for contact between the halo and the rear quarter. To see this area open the rear hatch, go forward to where the halo comes down and meets the rear quarter panel in the weather strip channel (see pic w/arrow). If there is a gap it’s likely not your source. If it’s making contact it creates a creak noise that sounds like it’s coming from inside the car in the area you describe.
In my case I found a small piece of dense foam or rubber pad that I trimmed to fit between the two body panels. You may have to loosen the closest screw on the halo to get a little bit more play to fit the buffer pad inbetween. It solved my issue, hopefully yours is a similar fix.
Bill
FL
Old Today | 04:44 PM
Pettrix's Avatar
Pettrix
Bill
FL
Thanks!
I will look at that tonight and hopefully that is the source. I can put some rubber between those panels to stop the creak noise. Much appreciated!
To Drivers-side B-Pillar Creak Noise
