Tire Flat warning on DIC
Old Yesterday | 06:06 AM
C6SEUSA's Avatar
C6SEUSA
Default Tire Flat warning on DIC
Yesterday my 2005 C6 suddenly displayed a warning saying my left front tire was flat. I drove back home and checked the tires. Most were measuring 26 PSI so none were flat. The doorframe label says they all should be 30 PSI. I drove away on my drive and the error did not return. Later in the day I pumped them all up to 30 PSI.
Any ideas as to what caused this warning? Is 26 PSI low enough to trigger it?
Old Yesterday | 06:11 AM
4SUMERZ's Avatar
4SUMERZ
26 psi is on the cusp of setting the iow pressure alarm. Once the tire warms up, the pressure will rise a bit to clear the alarm.
30 psi should be the lowest "cold" tire pressure that you should maintain for better tire wear.
Old Yesterday | 06:14 AM
C6SEUSA's Avatar
C6SEUSA
Thanks much! I was a bit worried I had a beginnings of a bad module like the BCM.
Old Today | 05:36 PM
C6ToGo's Avatar
C6ToGo
I think this is right.........
  • LOW TIRE PRESSSURE warning when below 25psi
  • FLAT TIRE warning when below 5psi and will trigger MAX SPEED 55MPH and REDUCED HANDLING nannies.
  • The sensors go through the Remote Control Door Lock Receiver (RCDLR) and if it was acting up you should get a SERVICE TIRE MONITOR message, not FLAT TIRE
  • XXX is usually a dead TPMS sensor.
Old Today | 06:11 PM
LouWinget's Avatar
LouWinget
I believe TPMS (Tire Pressure Monitoring Sensors) contain an internal battery. They don't last forever. If you get the Flat Tire message again on the same wheel it is probably a bad sensor which would need to be replaced (might s well do all four at the same time, too).
Old Today | 06:43 PM
C6SEUSA's Avatar
C6SEUSA
Thanks. I know that is costly and I probably should have had that done when my tires were replaced last October.
To Tire Flat warning on DIC
