c1 fuel gauge problem
Old Yesterday | 07:50 AM
63vette58's Avatar
63vette58
7th Gear
Default c1 fuel gauge problem
I know the c1 fuel gauge issue has been discussed many times. I did the brown wire removal and the fuel gauge went to full. When I grounded it, the gauge styed in the full position. Does this mean that the gauge is at fault?
Old Yesterday | 12:17 PM
jforb's Avatar
jforb
did you ground the wire at the sender end of the wire, or at the gage itself? if not at the gage, try it there before condemning the gage. Could be a break in the wire somewhere.
Old Yesterday | 02:39 PM
acstephenson's Avatar
acstephenson
... and even grounding the sender wire at the gauge isn't quite conclusive because the gauge itself must also be grounded. Never assume anything is grounded on a Corvette.
Old Yesterday | 03:41 PM
63vette58's Avatar
63vette58
7th Gear
I will try grounding at the gauge thank you
To c1 fuel gauge problem
