Preventative/Proactive maintenance @20 yrs old
I made a quick punch list and was hoping this could be helpful to others, or chime in on what else im missing that could be a good idea.
I daily drive it in summer and hit the track for a few HPDE as well - nothing too crazy, so all OEM+ philosophy here.
1) Serpentine Belt
2) A/C belt
3) All associates pulleys & tensioners
4) Alternator - mechman 250 (tolerates higher engine heat better)
5) DRM Bilsteins
6) Water pump to the OEM 2009+ style, and new OEM hoses/thermostat
7) Dewitts radiator (all aluminum, no plastic end tanks that can degrade over time)
8) AMT engine mounts (not leaking oil on degrading rubber OEM mounts)
9) Trans mounts, maybe Hinson (not as soft as OEM but not as severe as AMT)
10) SS brake lines
Considering non OEM harmonic balancer + front crank seal, but unsure if this maybe overblown "issue" like in my opinion the heads are.
Also considering DEI heat shields to the trans tunnel to help mitigate in cabin heat, but worried it will delaminate over time.
YMMV, but I'd inspect the belts and mounts and only replace if they showed signs of wear.
A car with 1200 miles could be slightly different than a car with 112,000 miles on it.
But, if you "daily" it and some HDPE's during Summer months, than it's a decent assumption that you're closer to the 112,000 figure that the 1200 figure, percentage wise.
Add:
Plugs & wires.
All fluids. All of 'em.
HB
