Exhaust Upgrades
Old Yesterday | 11:25 PM
QuickXSilver's Avatar
QuickXSilver
Cruising
Default Exhaust Upgrades
Hey everyone,
I’m looking for some advice on a planned exhaust upgrade for my 2015 C7 Z51, M7, factory NPP. The car already has the AFM valves bypassed/deleted, and I’m keeping NPP functional.
I picked up a complete OEM C7 Z06 exhaust system with about 7k miles, including:
  • Z06 exhaust manifolds
  • Z06 primary cats/downpipes
  • Factory center/X-pipe section
  • AFM/NPP hardware
  • Z06 NPP mufflers
My current plan is:
  • Install the Z06 manifolds and primary cats/downpipes
  • Use either an EOS or Speed Engineering X-pipe
  • Do a secondary cat delete
  • Install the lower-mile Z06 NPP mufflers
My understanding is that the Z06 exhaust manifolds/front section are different from the LT1/Z51 setup and should flow better. I also understand that the Z06 system is larger upstream, then necks down near the rear muffler/NPP section where it becomes similar or identical to the Z51 NPP rear section.
A few questions for anyone who has done this or measured the parts:
  1. Are the Z06 manifolds and primary cat/downpipes a worthwhile no-tune upgrade on an LT1/Z51?
  2. Is the Z06 center section larger than the Z51 NPP center section, or are they basically the same?
  3. Are the EOS and Speed Engineering X-pipes true secondary-cat-delete pipes, or are they more of a cat-back/connection pipe behind the factory cats?
  4. Between EOS and Speed Engineering, which one fits better and has better quality?
  5. Any drone concerns with Z06 manifolds/primary cats, secondary cat delete, and NPP mufflers?
  6. Are the Z06 NPP mufflers essentially the same as the Z51 NPP mufflers, or is there any confirmed difference in inlet size or tips?
I'm looking for a more aggressive exhaust that doesn't require a tune, I already have the Soler 91mm TB and the Vararam intake.
Any real-world feedback, measurements, or photos would be appreciated.
Old Today | 08:17 AM
smitty2919's Avatar
smitty2919
I wouldn't waste your time with any factory manifold. I have EOS 1 7/8" longtubes, stock catted x pipe and stock NPP and love it on my M7 GS.
EOS LT's bolt right up to the factory midpipe (which is what I wanted to retain cats for the smell). Zero drone with valves closed and rowdy enough with valves open.
AFAIK, all NPP systems are the same for base/Z51/GS/Z06. The only different muffler design is for the ZR1 NPP.
