Wires on positive side of coil
I have 2 connected, 1 being the condenser which the other side of it goes to ground, and one black/pink wire that goes into the engine harness.
I ask because it appears I'm getting no spark with the key in the start position, and normal spark with it in the run position.
I know the 12v on start is supposed to come from the "R" terminal on the starter solenoid. I can't see the solenoid right now because the starter shield is blocking access.
IF the wiring is right, I can think of only 3 things that could cause this:
1. a break in the wire at the "R" terminal
2. A bad solenoid that doesn't provide the 12v on start
3. a bad ignition switch.
Any help would be appreciated!
Jeff
Wire from ignition switch / ballast resistor - pink? Provides power in the ON position.
Wire from starter R terminal - pink? Provides power in the START position. MISSING?????
Wire from condenser / capacitor for radio suppression. Not needed with resistor plugs and plug wires.
I'll pull the starter heat shield and see if anything is connected to the "R" post. If not, I might just run a wire to it and replace the engine harness in the offseason.
Can you find the wire from the ignition switch to the R terminal in your wiring harness or where they come thru the firewall?
