Cluster issue
I am new here and this is my first post, hope i am doing this correctly. I have an 02 base convertible i just picked up. I am having an issue with the cluster lighting. When it is dark and you first open the door to enter the car all instrument lights illuminate,as they should but the minute you start the car it goes dark, no cluster lighting. Once you turn the car off, cluster lighting comes back on. i had read that the ignition switch could cause this, i replaced the switch and the problem still persist. Any suggestions for where i should look to next? Thank you all for your assistance!
While you're at it, check fuses and have someone confirm your brake lights and night time rear running lights are functioning as intended. Interior lights working?
