C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
RCDLR question
Old Jun 8, 2026 | 12:29 PM
ChetS's Avatar
ChetS
Default RCDLR question
The coax connection must have fallen off when I removed the RCDLR. Where does it come from, I can't see it. Second the two brass tabs in the cover have holes for screws but mine didn't have screws in them. They look like the could be for grounding? Thanks / Chet
Old Jun 18, 2026 | 11:25 AM
KENS80V's Avatar
KENS80V
There is no Co-ax connection to the RCDLR. I see no brass tabs on the exterior of my RCDLR. All connections are made with the two exterior connectors C1 and C2. Ground is located on pin "S" of C1 connector.
