C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
2008 Z06. I have enough injector and pump. Looking to throw a flex fuel sensor into the mix. Is there a kit that's better than another? Or are they all about the same?
It’s cheaper and looks cleaner to have your own fuel line made and just buy the sensor. I switched my DSX kit out and ended up running the fuel line through the rocker panel and hid it where the washer tank was along with the coil packs and pro speed breather
Here's what I did. I just ran my own signal wire to the ECM pinned it tapped into the fuse panel and ground point by passenger fender and use this radium split flow flex fuel sensor. The main fuel supply is not running through just the sensor so no disruption in fuel supply. been running it for 6 years perfect
Dsx is most popular. But the hardline they use sucks. I had it and then eventually got a radium engineering flex sensor adapter and an lines.
Looks great man! I like how you Incorporated the gauge in and it gives you more clearance to get in on the rail. My lazy *** took the easy way out and snapped her right on the rail and hammered on 😁 but yours looks good 👍
