Radio wiring schematic
Old Jun 10, 2026 | 01:16 PM
Mackee's Avatar
Mackee
Default Radio wiring schematic
I am about to replace the older kenwood radio on my c6 08 for an android. Since the kenwood radio installation may have changed the original radio connections, i suspect i would need
to find out about the connections for a new android. If you have an schematic, i'd appreciate your help!
Old Jun 10, 2026 | 03:00 PM
Superspirit's Avatar
Superspirit
I reccomend going to crutchfield and enter in your vehicle as they will tell you exactly what is needed.
Old Jun 10, 2026 | 04:43 PM
madsonp's Avatar
madsonp
What interface are you using ? These cars require the use of an interface to communicate with the cars canbus system, you just need to see what interface you have, find the installation instructions for it, and wire it up accordingly to your new head unit. While you're at it, I suggest also adding a back up camera, you'll be glad you did.
Old Jun 11, 2026 | 04:24 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
If it was installed right, the OEM wiring should be intact. Aftermarket radio harnesses only differ post OEM harnesses. Hopefully, your harnesses are intact and the new radio you want installed comes with a plug and play feature or an adaptor.
Old Yesterday | 09:08 PM
thedperrys's Avatar
thedperrys
You have some good suggestions already but here is what you asked for.
To Radio wiring schematic
