Options for ZF6 single mass flywheel
Old Jun 10, 2026 | 10:53 PM
Need4Sneed's Avatar
Need4Sneed
Default Options for ZF6 single mass flywheel
I'm in need of converting my old DMF with a solid disc but I'm not seeing too much talk about the Carolina flywheel, and even less on the Volunteer Vetter flywheel...
https://www.volvette.com/4SH51E.html
https://www.carolinaclutch.com/produ...steel-flywheel
I'm curious about the VolVette one as the listing claims the package weight is 15lbs but is $200 cheaper than the Carolina options, which they also have one around 15lbs. They look pretty similar but I'm wondering how the VolVette must have cheapened out on it. Thoughts?
Old Jun 12, 2026 | 09:23 AM
XLR8-R's Avatar
XLR8-R
Looks like billet steel vs cast iron. Cast iron is probably fine for stockish engine. You want the steel if you are going to rev it higher.
Old Today | 03:58 PM
D Dubya's Avatar
D Dubya
Summit should have a cast flywheel around $100 - $150 if cast works.
To Options for ZF6 single mass flywheel
