[C1] 1962 Hood mods for clearance
Old Yesterday | 11:58 AM
GVXCorvette's Avatar
GVXCorvette
Default 1962 Hood mods for clearance
I need to make room under the hood for the wilwood master cylinder in my 62. I have to cut away part of the hood near the hood latch on drivers side. Shown in picture.
Any recommendation on methods and perhaps a reinforcement for the modified hole. The red lines indicate what needs to be cut away.
Area to be cut away
Area to be cut away
Old Yesterday | 12:22 PM
Plasticman's Avatar
Plasticman
Before cutting away that important structural area, I would contact Wilwood..
They have to of had a problem like that previously, and hopefully a fix for the issue.
Plasticman
Old Yesterday | 12:44 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
There are other options out there than cutting the hood. I would think maybe changing to a lower profile brake master cylinder. I have one from MP brakes that fit under the hood. Yeah, give the company a call.
Old Yesterday | 01:37 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Probably not the same master/booster, bit I ran into the same problem and solved it by making a mounting bracket that lowered them enough to clear the hood.
Old Yesterday | 03:41 PM
TM61Vette's Avatar
TM61Vette
I used the corvette central master cylinder which initially hit in the same place. I then installed the U-shaped spacer shown below at the firewall and it angled the master cylinder down enough to clear the hood without modification. I'm not sure the spacer is sold separately but it could be worth a phone call.
58-62 Front Disc Brake With Dual Master Cylinder And Brake Line | Corvette Central
Old Yesterday | 04:37 PM
Corvette4me!'s Avatar
Corvette4me!
Yes, please don't cut you hood. Too many guys have done this without cutting, so hold tight until you come up with a non-destructive solution.
Old Today | 01:36 AM
GVXCorvette
Yes, they helped with this solution.
Old Today | 01:43 AM
GVXCorvette
I'm up against an air conditioning compressor and radiator pressure tank, and power R&P also in this car. I have spoken with numerous people when this system was built and none warned me of clearance issues, after already getting an adapter that moved it out and down
Looks like there is enough clearance to the hood
from the OEM three bolt master, to the 2 bolt wilwood design
Old Today | 01:49 AM
GVXCorvette
That's the spacer I have
Old Today | 11:56 AM
jforb's Avatar
jforb
The stock master cylinder (with RPV removed) works for me with Wilwood 4 wheel disc brakes. But maybe I'm special?
Old Today | 12:34 PM
GVXCorvette
jforb, Can I see a photo of what you have? What year car?
Yes, you are special
Old Today | 01:06 PM
Rusty60's Avatar
Rusty60
My bracket that mounts the master was slightly tilted down, this gives me the hood clearence needed.
you mention other things in the way, i will take pictures of mine tonight
are you able to get the fourth screw in to place the way it sits now? yours just seems really tight.
I am not familiar where the tank and A/C compressor sit in there
To 1962 Hood mods for clearance
