C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] My 1500whp 9000rpm Build
Old Today | 09:00 AM
Ravenrider1k's Avatar
Ravenrider1k
Default My 1500whp 9000rpm Build
Hi guys figured I’d make a thread if anyone is interested in seeing what consists of a 1500whp zr1 build that will still be daily driven. Figured I could keep all the info on here about the car if I were to ever sell it highly doubt it but.
Goal is to make 1200+whp boost only and spray how ever much to make up the 1500whp will have 3 tunes able to switch on the fly
Boost only Pump e85/Meth
Boost only C85 or Ethanol one r with meth
boost and spray C85 or Ethanol one r with meth
Motor:
388CI 11.5 Comp
Dart SHP Pro iron Block 4.125 Bore
ARP main studs
ARP 1/2 inch Head studs
Magnum LS7 3.622 stroke crank
Boostline 6.125 rods
Diamond LS2K pistons 4.125 bore
Cometic Head gaskets
rollmaster timing chain
Katech billet blue pump
ARP oil pan front and rear covers aswell as valley cover
Johnson 2126 axle oiling lifters
LME CID LS7-9 Heads
Crower shaft roller tip adjustable rockers
BTR valve covers
Manton heavy duty pushrods
LMP custom spec cam for 8000+RPM with .700 Lift 23*s of overlap
Blower:
Kong 2650 ls9 Ported
120MM TB
Kong gen3 LID
Kong 5 inch intake
14% lower
2.35% upper
Exhaust:
ARH 2 inch headers with catless x pipe
stock zr1 mufflers
Drivetrain:
SFI bell housing
HD Endlinks
AMT motor and trans mounts
Monster triple LT-1SC clutch rated for 1500whp
Texas drivetrain hardened prop shaft
DSS 1500HP drive shaft solid
MH3 Transmission with Texas drivetrain stage 2 upgrade
Stock Differential refreshed
ECS trans brace
Stock axles
Suspension:
Viking coil overs
LG drag sway bar
HD tie rods
15 inch conversion
Fueling:
Fore triple 535 pumps
RPM Meth kit
ID2600s injectors
ECU:
Holley dominator
Jumper harness so everything like factory works
8 Chanel EGT
Boost control Mac solenoid
Dual wideband NTK
Adjustable wheel speed traction control
Nitrous control
meth control
5 Bar map sensor
coolant pressure/temp sensor
Crank case sensor
Fuel pump control
Nitrous:
Dual 10lb bottles with billet brackets
Blanket heater
Kong lid direct port dry shot
Cooling:
Stock rad and fan
Ac condenser delete
Custom engine oil cooler
custom Power steering cooler
7 gallon extreme cfm ice tank
16AN lines
Edelebrock HX modified
EMP29/32 pump
Catch can:
Extreme CFM
Will keep updating with progress and pictures.
Old Today | 09:05 AM
Ravenrider1k
Old Today | 11:42 AM
Dzv69's Avatar
Dzv69
Thank you for sharing !! Pictures are excellent, looks like this isn't your first time taking apart and reassembling a C6 ZR1.
I noticed you are staying with the factory radiator and fan (rather than say for example a DeWitts Pro Series Direct Fit radiator with ProSpeed dual fans), and a "refreshed" factory stock rear differential (rather than say for example an RPM Transmissions Stage IV w/Wavetrac differential )
Old Today | 03:08 PM
Ravenrider1k
The diff I stayed stock at the time cause I was at 900whp but a built diff is pretty insane think we are talking 6000$ if I recall and have seen people break them as quickly as stock diffs. As for the radiator and fan I honestly didn’t have the budget for it last build and I never had AC in the car so even at 900whp in 100* weather back to back pulls at 900whp did not have any heating issues. Now that was on a sleeved ls9 block I may need to do the upgrade with this iron block and do the Dewitt’s with pro speed fan. But I’m going to give it a shot and see if it works I’m in California so it doesn’t get super cold here may run more water than coolant to help with temps.
And no sadly not haha this is probably my 4th time tearing this car apart but should be last im
hoping only thing I have to fix in the next few years is blown drivetrain parts.
Old Today | 04:22 PM
Colonel's Avatar
Colonel
"Hi guys figured I’d make a thread if anyone is interested in seeing what consists of a 1500whp zr1 build that will still be daily driven."
Why HELL YEAH I'm interested! I have just a little dailydriverlike bolt-on only ZR1 straining to push a measly 900whp but I LOVE these cars for their beauty and the potential they have. I certainly admire the guys who can and are willing to do most or all of the work themselves....not me for sure.
Old Today | 05:08 PM
Ravenrider1k
I have a little passion for doing the work mostly saves me about 30k in labor or so. Just sucks when you only have one toy and have to wait to play with it and you are just looking at it and working on it haha. Would be a lot nicer to pay someone and forget about it and get that call to come pick it up.
To My 1500whp 9000rpm Build
