Hi all,
I would like to see if any has a OEM steel fuel pump to carb fuel line for the base engine 350 quadrajet. I understand I can order from the vendors, but would rather
not deal with a pre=bent line that is bent incorrectly.
Anyone have one that has not been hacked up?
Joe ... just a suggestion but Inline Tube has by far the most accurate fuel pump to carb steel line. I have a 72 350/200 and have tried quite a few lines from different vendors and Inline Tube has the most accurate line out there. I liked the line so much that I bought a second line for a back-up just in case. Good luck in your quest.
