Programming key fob using Tech-2
Old Today | 04:36 AM
KokeZ's Avatar
KokeZ
Default Programming key fob using Tech-2
I know it’s mostly recommended to follow the trunk method but it’s known for being notoriously unreliable and unresponsive mostly for me so I give up additionally I lost the physical I’m relying on the physical lock cable also,
relying on tech 2 isn’t too bad but I’m stuck at single point which is after following theses step:
• Vehicle Control Systems
• Module Setup
• Remote Control Door Lock Receiver
• Program Key Fobs
• Next Available Slot (then they prompt me to check owner manual)
Then I get this
i get this note I put the car on ACC and turned the gear to D/R even tried it on P before entering vehicle control system moreover I used MDI-II
