grinding noise assistance
Old Jun 14, 2026 | 07:37 AM
Silver78_Vette's Avatar
Silver78_Vette
8th Gear
Default grinding noise assistance
Looking for some assistance and/or opinion on a consistent grinding noise coming from the rear of my ‘78 Silver Anniversary. It doesn’t happen from a cold start, it happens after I’ve been driving the car for a little while. It happens in fwd/rev and braking/not braking. I had the brakes replaced last year, and the leaf spring replaced. Thank you for any advice that anyone might be able to provide, or even any guess. I’ve had other non Corvette owners tell me that everything from that it could be the emergency brake rubbing something with the gear box, position differential. Quick Video attached (volume up).
File Type: mov
Old Jun 14, 2026 | 09:48 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
That's a tough video to separate the background sounds and it's very short. Is the noise you're talking about the rhythmic ratcheting sound in the first few seconds? Maybe better would be to drive the car and record the noise from the interior (windows up, radio off, smooth & consistent speed, at least 10 seconds long).
If you do hard turns to the left and right in an open parking lot, is the noise different in any way?
Do you feel it as a shudder or vibration when driving?
Does it sound as though it's coming from a specific side or just somewhere in the rear?
The emergency brake hardware isn't close enough to a gear box to have any effect. A binding emergency or disc brake will cause crazy-high heat on the bound side and easily felt with a touch of the hand on the wheel's hub.
One more question: was the change of brakes and spring an attempt to address this or did the noise appear after the work was done?
Old Jun 14, 2026 | 09:57 AM
69L88's Avatar
69L88
Check the end play of the differential stub axles. In severe cases, you can see damage to the differential housing as the U-bolts start fly cutting the housing.
If no damage, add a couple bottles of Delco 10-4003 to the differential and do some slow figure 8s to get the additive into the posi clutch plates.
Old Jun 14, 2026 | 10:41 AM
Silver78_Vette
8th Gear
Thanks for the reply Unfortunately the site will only me to upload a video no more than 4-5 seconds
To answer your questions:
- the noise is towards the end of the video. It sounds like someone walking on creaking hardwood floors
​​​​​​- the noise doesn’t seem to happen when driving straight—only very low speeds, forward and reverse, and when the wheel is turned (even slightly)
- it’s definitely coming from the rear. Maybe more the passenger side.
- I don’t feel a shaking, vibration(s), of the car
- the brakes were not replaced due to this and leaf spring was optional (lighter one)
Old Jun 14, 2026 | 11:20 AM
Purple92's Avatar
Purple92
You might want to get an inexpensive IR temp "gun" that lets you read component temps. Go for a few mile ride, and check the brake rotor temps (you should be able to do it "through the wheels" - or from the inside). Both rear wheels should be roughly the same - if one is significantly higher - that indicates a brake is dragging.
But if it happens ONLY when the car is turning - I would tend to suspect something diff related. I'd probably drain the diff fluid, and put in new fluid with some of the Delco Limited Slip additive that 69L88 mentioned above.
Old Jun 14, 2026 | 01:22 PM
USMC6113's Avatar
USMC6113
Check the fluid level in the differential.
Old Jun 15, 2026 | 08:42 AM
Radovette's Avatar
Radovette
My 78 had similar issue after a brake job. The pin that keeps the pads in place lost its cotter pin and the pin would randomly back out and crash into the wheel rim. Made s horrible grind. Sounded like it was from the differential but actually was the right front brake. Easy check-easy fix.
Old Jun 15, 2026 | 09:40 AM
GTR1999's Avatar
GTR1999
Typical noises
  1. Posi clutches- usually shows up after driving, coming to a stop, turning left or right, chattering from the diff.
  2. Parking brake hardware, springs break, shoes drag, creates a lot of heat and noise. If the rotors are still riveted on that is a clue.
  3. U-joint bind from worm, rusty joints
  4. Bad rear outer bearings
  5. Differential axles hitting the housing, metal scrapping sound. 78 differentials had issues.
I could not tell much from your video. I would do a little homework on how these items work, then jack the car up and check each one. If you are mechanical, you can probably do a better inspection than some local garage without much experience with old vettes can.
Old Yesterday | 11:43 PM
loflite's Avatar
loflite
I've got the exact same thing going on with my '76. Changed out the differential fluid with 2 bottles of additive. Did not change anything. BTW, the differential was extremely low when I drained it. (sucked it out). The differential has 115k miles on it and has never been overhauled. Been meaning to check the u joints and brakes. The bearings are good. Too busy to check right now. I can not tell what noise you are talking about in the video, but your description is mine exactly. I will post my findings if I figure something out. Please post if you figure your noise out.
To grinding noise assistance
