[C2] Body Dolly Question
How much of the top plate that ties the 4x4's and the 2x4's together do I need to cut out?
Am I correct that the car body mounts sit directly on top of the 4x4 and the top plate only
needs to be notched out to clear the rest of the body?
I mocked up a top corner, which of course is upside down. Picture attached.
Second question is about the casters. I'm thinking 4 fixed and 2 swivel to give it some stability when working on the body, but still allow it to be moved around.
Anyone have a recommendation on size, composition and brand?
Thanks
I used all swivel wheels with brakes on them.. They were spendy but its made life easier moving my body around.. I only set 2 or 3 of the brakes when I park the dolly/body...
Darin
Jaced up one side to get hoist under it. Akward, but worked.
One problem I had was with the bracing in place it was impossible to crawl under the cockpit itself. This was solved by modifying a section so it could be removed when needed and bolted back up when stability was important.
