Did I ruin my C3?
Old Jun 15, 2026 | 05:39 PM
Vettenovice952's Avatar
Vettenovice952
3rd Gear
Default Did I ruin my C3?
I am trying to fix up a 1980 Corvette 305 engine. I replaced the intake manifold gasket since it was leaking oil. I tried following many videos on how to complete and being as careful as possible. I also removed the emissions equipment while I had everything off. After reassembling the car, I turned it on and revved the engine. I heard a loud noise, and the engine turned off. I noticed coolant leaking over the starter. I drained the coolant and disconnected the battery. I have not touched anything else. I read on old threads that I possibly hydro-locked it, and it could have caused severe damage. I am going to have it towed to a shop, but I wanted to know how it could have happened, whether the engine is ruined, and if there is anything else I should do to the car to minimize damage before going to the shop?
If anyone has any experience with this, please let me know.
Old Jun 15, 2026 | 05:54 PM
carriljc's Avatar
carriljc
Vettenovice952
Don't change anything else and take a bunch of pictures with good lighting.
IF you broke something where the water came out then you should be able to locate that leak (or rupture) by adding water back.
Go search for and see you see that. Also, check the oil to see if it has water it.
No need to freak out just yet.
BUT a question: How did you set your timing after putting everything back together?
Old Jun 15, 2026 | 06:27 PM
Vettenovice952
3rd Gear
Originally Posted by carriljc
Vettenovice952
Not much leaked out initially; it took one rag to wipe up. The trail seems to be coming from the intake manifold joint where I replaced the gasket. I will add water back in to try to find the leak. The dipstick showed no signs of coolant.
I followed a video I watched, and I marked the intake manifold and wall with the angle of the distributor. I then placed everything back as they were using the markings. I did not set the timing myself. Would this have caused the issue?
Old Jun 15, 2026 | 07:18 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
What kind of noise was it?
I think first you want to see if the engine damaged a valve, piston, or rod. Remove all the spark plugs and, using a socket and long bar on the crankshaft bolt below the fan, see if you can roll the engine over two full rotations. If you have coolant in a cylinder this should also force out any puddle of significance, so examine the spark plug holes and sides of the block below for coolant.
I'm not sure you can see coolant on the dipstick if it's a small amount unless it ran long enough to mix the fluids into a coffee w/cream color. The oil will float on the coolant so you'll only see a small bit of added volume in the pan - maybe too small to see. You can drain off a quart from the drain plug to see if any coolant entered the oil system.
Old Jun 15, 2026 | 08:01 PM
orourke's Avatar
orourke
Probably got your distributer off one tooth. +or-.
Old Jun 15, 2026 | 11:12 PM
Bikespace's Avatar
Bikespace
Think of it instead of creating an opportunity! Unless you live in California, you are now free to replace the worst engine GM ever put in a C3 with something much better. You can ditch the computer controlled carb and dist at the same time.
Please post some photos without the air cleaner assembly. Perhaps someone already did that second step.
Old Jun 15, 2026 | 11:19 PM
socal_tom's Avatar
socal_tom
If you didn't turn the engine after pulling the distributor you could not have hurt anything to bad, maybe a tooth off as someone stated. but if you adjusted the valves you could have more problems. What it sounds like is a backfire and the timing is off . I don't see how you could hurt anything. You need to get the engine to top dead center and see where the rotor is pointing
Old Jun 15, 2026 | 11:27 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Did your engine crank and idle normally before you revved it up?
The engine usually wont crank over or it will turn over very slowly if hydrolock happens.
Once the cylinder that is full of coolant reaches the compression stroke is when the hydrolock occurs.
I hydolocked my engine once but quit trying to crank it once I heard the starter bog down. The problem turned out to be a tiny 1/8" diameter flat washer between the intake gasket and head allowed coolant to leak into the cylinder near the flatwasher.
socal_tom's Avatar
socal_tom
Chevys can take a lot of abuse, ask me how I know
Old Jun 15, 2026 | 11:31 PM
doorgunner's Avatar
doorgunner
Originally Posted by socal_tom
chevys can take a lot of abuse, ask me how i know
exactly!
Old Jun 15, 2026 | 11:49 PM
OldCarBum's Avatar
OldCarBum
I post #1 you stated that you replaced the intake gasket.
Did you just replace one intake gasket or all the intake gaskets?
How long did the engine idle and how was it idling before you revved it?
How high of rpm did you rev the engine to and for how long?
Post pictures and check the items suggested above, then report back before towing it to a garage.
Old Yesterday | 09:59 AM
Vettenovice952
3rd Gear
I have very limited knowledge about cars. I started this project wanting to learn about cars so I can help my son whenever he grows up. And I did learn something. I learned I'm an idiot. I installed the intake gaskets upside down. This caused coolant to leak when the engine started and created a vacuum.
The car was idle for about 5 seconds or less. I started but stumbled and died, no weird noises. Which I thought was normal for a car sitting for a couple of days. After starting it a second time, I gave it a little gas up to 1000rpm. As the RPM was dropping, it made a knock, and the engine died.
I had to go into work, so I haven't had time to check for bent rods yet. I will update today with the extent of the damage later today.
Old Yesterday | 09:20 PM
OldCarBum's Avatar
OldCarBum
You bought the car to learn.
Now you are learning and will have more knowledge as you move forward.
What ever you do, it doesn’t hurt to post pictures and ask questions.
You we’re smart by letting it idle and just increasing the rpm a little bit.
Keep asking questions, we are here to help.
I’ve been around cars, boats and motorcycles all my life and learned a lot over the years.
My 73 build project is my first Corvette and I knew nothing about these cars when I started.
I’ve learned a lot about this car but I know nothing compared to some of the guys and gals on this forum.
I ask a lot of dumb questions, trust me I do!
Old Yesterday | 10:21 PM
Eliredandblack's Avatar
Eliredandblack
I can tell you honestly that you aren’t the first person to install head gaskets on BACKWARDS. While in high school a buddy and myself replaced the heads on a friend’s 327 Chevy, he paid us $ 10. Needless to say we had to repeat the job, and even buy a NEW Set of head gaskets. It’s easy to guess why I never became an auto mechanic? Oh, it was in the winter, and the car was parked outside. 😬😬😬
Old Yesterday | 10:22 PM
Bikespace's Avatar
Bikespace
Hopefully you'll be back on the road soon, and no permanent damage was done.
If you insist on continuing to learn about Gen 1 SBCs, pick up a copy of David Vizard's book. (This is an updated book, the one I have is now out of print and $300-!).
Or, you could take this opportunity to do what GM did, learn from 40 years of development, and pivot to to the Gen III or Gen IV LS engine platform instead.
There is zero coolant in the intake of an LS engine, and the amount of RTV silicone used to assemble it is equivalent to a day's worth of toothpaste. It goes together like LEGOs, and gives you EFI and a roller cam for free!
To Did I ruin my C3?
