Sponsored by: Wheel Design
Warranty on C8 HTC repairs
Old Jun 15, 2026 | 09:40 PM
rrichar2591's Avatar
rrichar2591
Default Warranty on C8 HTC repairs
A couple of weeks ago, I experienced the broken cable on my 2023 HTC with 18,000 miles on it. Luckily, I had the zip ties with me and got the top back up. The dealer ordered the new cable assembly and got the repair completed today.
The good news is that the Platinum extended warranty covered everything. Total bill was approx 450 dollars.
There has been a lot of discussion whether the warranty would cover HTC top repairs but in this case it did. I thought this might be good information for some of you with the same concerns.
Old Jun 15, 2026 | 09:47 PM
Tonylmiller's Avatar
Tonylmiller
how much did the warranty cost?
Old Jun 15, 2026 | 10:05 PM
RKCRLR's Avatar
RKCRLR
This is a good data point. Some people have had the CPPP deny this coverage. The more people that get it covered the more leverage we have that it should be covered.
Old Jun 15, 2026 | 10:20 PM
Zymurgy's Avatar
Zymurgy
Moderator
Greatly depends on who you buy it from and the terms (months/miles) as well as the age and miles on the car when you buy the warranty.
Old Jun 15, 2026 | 11:12 PM
rrichar2591
I bought the warranty from Todd Sutherland two years ago. It was for 96 months and 80,0000 miles. Total cost was 2,185 dollars. The service writer had no problems at all getting it approved.
Old Yesterday | 12:23 AM
Stoopalini's Avatar
Stoopalini
Glad they took care of you.
I’ve seen mention of the zip ties a few times now. Curious how they come into use when this issue occurs?
Old Yesterday | 06:19 AM
Joe's Eray's Avatar
Joe's Eray
Is this a common issue when the HTCs get older with the cable going bad?
Old Yesterday | 06:33 AM
V Vette's Avatar
V Vette
Thanks for info. Can you show/explain the zip tie temp fix?
Old Yesterday | 08:27 AM
Ozarks 70th HTC's Avatar
Ozarks 70th HTC
That’s great news! That’s one area I’ve been concerned about since purchasing my Platinum plan from Todd. I do need to add some zip ties to my car. Thanks for the info.
Old Yesterday | 08:43 AM
tsigwing's Avatar
tsigwing
When my 2nd cable broke out of warranty, it was not covered:
Keith Overturf <Keith.Overturf@huffines.net>
to me
Mon, Dec 16, 2024, 7:49 AM
I CALLED YOUR EXTENDED WARRANTY (GM PROTECTION PLAN) AND THE CABLE/BRACKET IS NOT COVERED.
THE PART IS $238.27 AND TH LABOR IS $175.00
I also have the platinum warranty.
Old Yesterday | 10:05 AM
McBeef's Avatar
McBeef
Quick question on the broken cable.
I'm on my 2nd HTC. My 23 roof went up/down smooth and quiet. In my 26 down is smooth/quiet, up is a bit different. When the roof going up meets the A-pillars, one side gets there about 1/3 of a second faster and there is a audible "clunk" and (this might just be my anxiety) it feels a bit rough compared to my 23. I'm wondering if you noticed anything similar before your cable broke. Not sure what I'm describing is a potential issue or within normal parameters.
rrichar2591
So when you say the 2nd cable was not covered, did the first one get replaced under warranty? The dealer that replaced mine yesterday told me there was a two year warranty on the new cable assembly regardless of the extended warranty.
Old Yesterday | 10:15 AM
rrichar2591
I did not notice anything out of the ordinary, but there was a loud bang as I was lowering the top. When I tried to put the top up again I noticed the flap on the driver side was not retracting. A friend manually retracted it for me while i zip tied it to the bracket right behind the cable.
I have read somewhere that the tops can be adjusted when they are somewhat out of sync like yours may be. It may be worth a call to the dealer just to see.
Old Yesterday | 02:15 PM
mikebutson's Avatar
mikebutson
Lucky you it was covered...I also have a 23, and I must say, I think about this happening every time I open the HTC and my zip ties are in the frunk...Fingers crossed, all good so far. Still can't believe GM hasn't issued a Bulletin for all HTC owners to get this fixed, since this has been an issue since the C8 was introduced and continue to be an issue and shouldn't cost the Owner a penny to fix, but it is since Warranty is up when it happens for many....Do you happen to know if the Dealership installed the exact same cable or was there a new design (more robust) cable?? If not, I'm sure it's only a matter of time before it breaks again? GM really dropped the ball on this one....
Old Yesterday | 02:18 PM
PaulCPO's Avatar
PaulCPO
Fwiw. Mine does the same thing
Old Yesterday | 03:01 PM
tsigwing's Avatar
tsigwing
First one was one side, under warranty. 2nd was the other side, out of pocket.
Old Yesterday | 03:17 PM
saleen556's Avatar
saleen556
Glad to hear it was covered. I’ve got 18k miles on my 23. What cable is breaking and how long of zip ties does one need to temporarily fix it?
To Warranty on C8 HTC repairs
Old Yesterday | 03:25 PM
rrichar2591
That may have been worth a call to the warranty company just to try to understand their reasoning.
Old Yesterday | 03:32 PM
rrichar2591
I asked that question and the service writer didn't know. She did mention the new part comes with a two year warranty however good that is.
I have decided from now on to keep the zip ties in the glove box not knowing if the frunk will open while the top is not working. I was at a car show when this happened and luckily the frunk was open.
Old Yesterday | 03:44 PM
Zymurgy's Avatar
Zymurgy
Moderator
Covered or not? In the Exclusions section of the contract is the following:
5. EXCLUSIONS FROM COVERAGE
THIS AGREEMENT WILL NOT PAY OR REIMBURSE YOU FOR: A. ANY LOSS, DAMAGE OR EXPENSE CAUSED BY ACCIDENTS, ANY ALTERATIONS OR ADDITIONS TO THE COVERED VEHICLE OR THE PART, USE OF OVERSIZED OR UNDERSIZED TIRES OR WHEELS, ALTERATIONS OR ADDITIONS TO THE COVERED VEHICLE NOT AUTHORIZED BY ITS MANUFACTURER, ANY NONMANUFACTURER/NONFACTORY INSTALLED PARTS, THE FAILURE OF ANY PART NOT COVERED BY THIS AGREEMENT, ACCIDENTAL LOSS;
HARDTOP ASSEMBLIES, BUMPERS, TRIM, MOLDINGS, DOOR PANELS, DOOR HANDLES, DOOR LOCK CYLINDERS (OTHER THAN IGNITION LOCK CYLINDERS), TIRES, WHEELS, WHEEL RIMS, WHEEL COVERS, WHEEL BALANCING, WHEEL ALIGNMENT (UNLESS THE WHEEL ALIGNMENT IS REQUIRED FOR THE REPAIR OF A COVERED PART), BATTERIES (EXCEPT FOR HYBRID/ELECTRIC BATTERIES), WIPER BLADES, BRAKE PADS AND ROTORS, LIGHTS, FUSES, BULBS, FILTERS, LUBRICANTS, OR FLUIDS NOT REPLACED IN CONJUNCTION WITH A COVERED REPAIR, UPHOLSTERY, VINYL AND CONVERTIBLE TOPS, PAINT, BRIGHT METAL, SHEET METAL, FREEZE PLUGS, HEATER AND RADIATOR HOSES, EXHAUST SYSTEM, CATALYTIC CONVERTER;
The wording is certainly not very precise, especially as the phrase is "vinyl and convertible tops". That appears to be relevant to a soft convertible top, not to the HTC mechanism.
So, we have it getting covered sometimes and not covered other times.
