[C2] '66 327 w/ AC coupe suspension springs help
Old Yesterday | 10:16 PM
cbucgo's Avatar
cbucgo
Default '66 327 w/ AC coupe suspension springs help
my corvette rubs the battery access cover when I turn the steering wheel to the left.
I am thinking to replace the coil springs and the rear leaf spring but I see zip corvette has a few options and corvette central has more options.
Where's the best place to get this stuff?
How do I know what springs and leaf spring I need?
Old Yesterday | 10:21 PM
anyChevy's Avatar
anyChevy
What size wheels and tires are on it ?
It would also help to post a photo of your car “side on” in case there’s some alignment issue.
Old Today | 10:23 AM
thoyer's Avatar
thoyer
There are a lot of things that need to be checked before you start throwing springs at it.
The AIM has suspension height spec's that should be checked and will tell you if your springs are sagging.
As was asked - what tires are you using?
Old Today | 10:31 AM
1Hotrodz's Avatar
1Hotrodz
You might be able to correct this with the alignment settings. Look at the lock to lock steering wheel specs, make sure they are equal turning left and right. Then the usual Align. settings. My guess is Toe-in is correct but not centered.
Old Today | 10:36 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Caster will also move the wheel forward or backward in the opening.
Not having an A/C car I don't know this: isn't the access panel pretty flush with the rest of the inner fender?
Old Today | 01:06 PM
thoyer's Avatar
thoyer
It does have a bump out - Dave did an article that has a pic
https://www.corvetteforum.com/forums...-pb-coupe.html
Old Today | 01:18 PM
barkingrats
Oh, I see now - thanks for the link.
Old Today | 06:47 PM
cbucgo's Avatar
cbucgo
I got a set of knockoffs with goldline radials direct from Zip Corvette specific to the ‘66. Will look at the size once I get home
i will post a photo tonight if I get home before dark. If not I’ll post tomorrow.
Old Today | 07:11 PM
pop23235's Avatar
pop23235
My 65 vert 365 with AC is running 2:15s without rubbing.
Old Today | 08:11 PM
anyChevy's Avatar
anyChevy
I will post a photo tonight if I get home before dark. If not I’ll post tomorrow.
That will help, if you look down a few threads, you’ll see my AC coupe, which is pretty low and doesn’t touch anywhere with 205/70s so it’s possible something is off.
To '66 327 w/ AC coupe suspension springs help
