How to fix broken exhaust studs??
Old Yesterday | 12:20 AM
JohnH77's Avatar
JohnH77
2nd Gear
Default How to fix broken exhaust studs??
Thinking about trying an extractor but I wanna see if you guys have had this problem and fixed it. I’m afraid of making it worse. I already have replacement studs and hardware. Just wondering what the easiest way to remove the old studs is. I couldn’t get vice grips to work
Old Yesterday | 05:49 AM
SideOfTheRoad's Avatar
SideOfTheRoad
Use heat on the exhaust flange, and a stud extractor to grip the stud. I've also had good results using the crayon method circulating on social media, it works.
Old Yesterday | 06:03 AM
the_merv's Avatar
the_merv
Jam up two M10x1.5 Nuts on each and heat on the Flange, twist right out. If they are press in, heat the Flange and drive them out.
Old Today | 02:29 AM
CFight's Avatar
CFight
Excuse to buy headers.
If you weld you could cut them below flange and weld all thread onto them.
To How to fix broken exhaust studs??
