I believe the parking lights and tail lights are on the same fuse, wiring, and grounds. The only variable would be the position of the light switch. Try putting the headlights / tail lights on and pushing in and out and twisting the **** while watching for any flicker at the tail lights. Just a guess, the smarter guys will be along soon.
Yes .I will try that tomorrow and maybe a ground issue. Going to bed now . I will wake up and look for those smarter guys in the morning.LOL
Ty
I doubt it is a ground issue if both tail lights are equally bright in the park position and if the brake and turn signal bulbs work. All use the same ground.
I am not the sharpest knife in the drawer, but my wife claims my family comes from the butter knife drawer.
The aftermarket light switches don't have a good reputation. I would disassemble the original and inspect, clean, burnish if needed, lube and reassemble if it is not trashed.
JMHO
The tail lights and parking lights are on different circuits and do not feed from the same fuse. In fact the parking lights are not fused anywhere. The voltage comes from the purple wire on the headlight switch connector. Unless someone has moved the purple wire from the stock position to the available lug on the headlight switch, they will go off when the switch is pulled to headlights on position as designed. Since your park lights are working correctly, that means you have a problem in your headlight switch that causes it to lose connection to the brown wire that feeds the voltage to the tail lights when you pull the switch to the headlights on position. It's the same brown wire that feeds them in the park position. The voltage has to be there in the park position or they would not be working in either position of the switch. The only change would theoretically be in the headlight switch contacts internally.
Just to see what happens, I'd try pushing the headlight switch back and forth between park and on rapidly several times and see if that clears off some corrosion on the contact and they start to work.
my dash lights and rear tails will go off if dimmer in the right position.
I definitely need a new switch me thinks
The rheostat has no connection to the tail lights, only the dash lights. The only common thing between the two is that you are wiggling the headlight switch shaft when you rotate it. possibly moving the internal contact exactly like the original post here describes.
