sudden oil consumption thoughts please
PS - Not the Corvette, but another Chevy.
Checked the PCV valve and it rattles, no excessive oil noted.
Did a cold compression check and have #1 - 175, #3 - 170, #5 - 187, #7 - 170, #2 - 180, #4 - 180, #6 - 180, & #8 - 175. I double checked the compression thinking I might have a broken compression ring from the lean burn of the ethanol, but these numbers don't show anything. Have not done a leak down test yet. No noticeable smoke at hot idle in the garage or on restart.
I pulled a couple of plugs when checking for damage after the ethanol and they were 'white' and very clean, but no noticeable electrode damage. I pulled all eight for the compression check today and now have a bit of black carbon on the plug and some with a bit of oil on the threads, but none oily on the electrodes. The plugs are Bosch Platinum WR9FP R6 671.
The engine is a 350 +.030 with L79 cam and 10.5 / 1.0 forged pistons but ~9.5 to 1.0 with composite head gaskets under 462 camel hump heads . About 100K+ miles on the engine.
Any thoughts on where it is going? I do have some minor leaks at the front crank seal and rear main seal.
Thanks in advance.
Ron
I think I'll hang a couple of white towels over the tail pipes and see what I get.
R66 327 had stuck oil rings but it was smoking even at idle.
I'll check the vented cap and also the PCV vacuum tomorrow.
