[C2] Least expensive route to 500hp
Old Yesterday | 10:03 PM
agassi70's Avatar
agassi70
Default Least expensive route to 500hp
Is an LS swap (which LS model) or building a 383 possibly the least expensive route to the 500hp route? Mainly an interstate driver.
Old Today | 12:21 AM
c2vettehead's Avatar
c2vettehead
383 definitely will be cheaper.
afr heads, roller cam, etc... can get you to 500 for less than $8k me thinks.
LS376 crate will get you 525hp, but will cost you at least $14k with all the EFI stuff you'll need. unless you want that carbureted. then maybe $11k
Old Today | 04:18 AM
DiabolicalDave's Avatar
DiabolicalDave
Also, going LS means none of the factory brackets, exhaust, shrouding, and related stuff will properly fit.
With the 383, you "only" change the guts of the engine, basically.
And, I agree a properly build 383 will get you to 500+ hp for the lowest cost, most likely.
To Least expensive route to 500hp
