Problems with the carbon fiber dashboard replacement
Old Yesterday | 08:11 PM
JorgeAM's Avatar
JorgeAM
Default Problems with the carbon fiber dashboard replacement
Today I replaced the plastic dashboard with the OEM carbon fiber one, and everything went well except for the climate control *****:
The one that adjusts the temperature is a little harder to turn than before, but the one that controls the fan speed is much harder to turn—as if the dashboard were thicker and the **** were hitting it. If I move it back a little, it turns normally.
Has anyone else on the forum had a similar problem?
Thanks so much for the help!
Old Today | 07:48 AM
smitty2919's Avatar
smitty2919
Trim the backside of the **** to have it rotate freely.
Seems the dash piece may be slightly bent/bowed?
Old Today | 08:10 AM
JorgeAM's Avatar
JorgeAM
Thanks for the help! At first glance, it looks straight, but it seems a little thicker than the dashboard, and that might be the problem.
I'll have to trim it a little, then, even though I was a little scared to touch it!
Old Today | 01:09 PM
smitty2919's Avatar
smitty2919
I wouldn't trim the dash. I would simply trim the backside of the plastic **** instead. Those are probably cheap and easy to replace.
Old Today | 01:50 PM
kodpkd's Avatar
kodpkd
I would also make sure the push in tabs are pushed all the way in. Go around the infotainment screen and push the 3 pins.
To Problems with the carbon fiber dashboard replacement
