Found what I consider a good deal on a 92 Coupe ($1800).
Known issues:
Dash has been taken apart to troubleshoot Crank no Start condition. Seller claim is that after removing the factory radio and putting in an aftermarket one, a crank so no start condition resulted. He started tracing wires from the radio and pulling the dash apart in the process.
I will be putting the dash back together along with all the wiring and would love to hear any ideas on how to proceed from that point. Gemini said that the neutral safety switch wire is a likely culprit and there is a TSB for this model (92-322-6D).
From 300+ miles away I will say that's a good deal - but condition overall is important. Also it'd matter how bad they butchered the wiring trying to 'fix' it.
"IF" what they say is true I would put $25 on the neutral wire thing you mentioned is not the problem.
