C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Clicking at full steering lock to right?
Old Jun 19, 2026 | 10:24 AM
fullsmoke's Avatar
fullsmoke
6th Gear
Default Clicking at full steering lock to right?
Hello,
When turned fully to the right and crawling at slow speeds, I hear some clicking from what seems like the driver front wheel well. It's a rhythmic click happening at regular intervals as I go in circles. Turning to full left might be making a noise too, but I can't really tell. This started happening yesterday (~1400 miles on ODO).
Are there any specific areas to check under the car? Most of it is covered by plastic so I can't see much. Anyone else have this issue?
Thanks,
FS
Old Jun 19, 2026 | 11:00 AM
MikeR397's Avatar
MikeR397
Have the same thing, carbon wheels and brakes, I’ll let others chime in on the issue but I think it’s the wheel mounting surface itself? I have no rubbing on anything or issues on track besides clicking around some corners on track occasionally but less lately, as well as slow full lock.
Old Jun 19, 2026 | 12:30 PM
Mitchell_B's Avatar
Mitchell_B
The wheel(s) have to be removed, both the hub and wheel mating surfaces must be cleaned, apply a very light coating of anti seize spread on the wheel mounting surface, install wheel(s) and torque lug nuts in sequence (star configuration) to spec in 3 stages. GM has a maintenance directive on this with a lubricant they spec. Anti seize to be used very sparingly. Check lug nut torque after 1000 miles.
Old Jun 19, 2026 | 03:34 PM
Kenny94945's Avatar
Kenny94945
Post # 3... the directive.
Do any of my co-members have this and can post so I could print it?
Old Jun 19, 2026 | 04:21 PM
Cobo_pro's Avatar
Cobo_pro
Just verifying that you are describing is not the "Ackerman effect", right?
Old Jun 19, 2026 | 04:36 PM
Matthew Griffin's Avatar
Matthew Griffin
It's a bit of both.
It mostly goes away when running the PS4S. VERY pronounced with the Cup2R or the P1X's.
Old Jun 19, 2026 | 04:37 PM
Cobo_pro's Avatar
Cobo_pro
Agreed, car's currently at Chevy going from Cup to ps 4s. Longest 2500mi (street driving on the cup 2r) of my life 🤣
Originally Posted by Matthew Griffin
It's a bit of both.
Old Jun 19, 2026 | 05:59 PM
lgodom's Avatar
lgodom
I don’t have the TSB handy but if you do a search in this forum for it there’s a discussion about a week ago where I posted it. The super lube mentioned in the TSB isn’t applied to the entire rotor hat surface. It’s only applied to the pilot bushing where it goes through the rotor. I’ve performed it a couple of times to my car. It’s a great time to clean the inside of the wheels or ceramic coat them while they’re off the car.
Old Jun 19, 2026 | 06:35 PM
Mitchell_B's Avatar
Mitchell_B
Attached
File Type: pdf
Old Yesterday | 08:26 PM
fullsmoke's Avatar
fullsmoke
6th Gear
Update:
Not Ackerman effect. I am on PS4S.
Jacked up the car this past weekend and did not find anything damaged with suspension. Also, the noise mysteriously disappeared.
Maybe dumb question, but ff I were to removed the wheels, how do I not damage/mar/scratch the black chrome lugs?
FS
Old Today | 12:12 AM
srewood's Avatar
srewood
All the c8s seems to do this. My SR did this and my z06 also does this. My c8 sr actually did it for probably 10k miles or more and then one day it just went away and never came back. It did it a lot. My z06 barely does it but it does do it a tiny bit.
Old Today | 05:55 AM
VinnyP's Avatar
VinnyP
Originally Posted by fullsmoke
Update
FS
Amazon.com: RIGOR 11506 22mm Non-Marring Lug Nut Socket | Wheel Protector Impact Socket | 1/2" Drive, 6 Point, CR-MO, Metric : Automotive Amazon.com: RIGOR 11506 22mm Non-Marring Lug Nut Socket | Wheel Protector Impact Socket | 1/2" Drive, 6 Point, CR-MO, Metric : Automotive
I use this socket. Its far from fool proof but it does help. I also loosen and tighten by hand, then torque to 140 lbs. I use these as well to help get the wheels off and on . Again, not perfect but helpful to not damage the calipers , wheels, rotors.
Amazon.com: Steelman Wheel Alignment Pin Set, M14 x 1.5 Female Thread Pilot Guide Lug Bolt Tool, Stainless Steel, for Vehicles with Studs, 200mm Length, 3-Pieces (61013) : Automotive Amazon.com: Steelman Wheel Alignment Pin Set, M14 x 1.5 Female Thread Pilot Guide Lug Bolt Tool, Stainless Steel, for Vehicles with Studs, 200mm Length, 3-Pieces (61013) : Automotive
Old Today | 07:41 AM
Cobo_pro's Avatar
Cobo_pro
Ackerman effect is not eliminated by tire choice. I had it worse in my SR with PS4S than i did with my Z on Cup2R, so flawed logic if thats the only way you ruled it out.
These cars are not meant to be turned fully in either direction at any speed, and the quicker the speed at full or near full turn radius, the more the tires will "hop" across the pavement.
+1 on the non-marring sockets posted above. I use those too
Update:
FS
To Clicking at full steering lock to right?
