Limp mode a few miles after mod installs (TBs, Eventuri, Cat deletes)
Upon first start, everything was fine. No CEL. I did the relearn procedure where you turn the car on for 3 minutes, turn it off for 3 minutes and do this cycle 3 times then drive it for a few miles. Everything seemed to be fine, so I went home. About 20 minutes later I went out again and symptom #1 started. In 1st gear, if you applied acceleration from a stop, the RPMS would stay up and it seemed like the throttle was stuck on/would not decelerate. Changing gears, speeding up or applying the brake would make it go away, so I figured maybe it just needs some more time to learn the new airflow mods. About 10 miles later, the car goes into limp mode. Almost like it was misfiring real bad -- the car sounded like it was cammed. I was able to get home and decided to pop the trunk and take a look and see if something wasn't plugged in correctly. Symptom #2 - The cat deletes were GLOWING red and it felt like 1000 degrees in the engine bay (I wasn't driving the car hard at all, never even went over 55mph). Not sure if they were already like this or if it started after the CEL, or if the CEL was caused by the heat. The temperature on the dash was bouncing from 188-209 on my drive home in limp mode which didn't seem to be terrible. Symptom #3 - I have a code reader, so I ran the codes after I got home and found an active P0639 code Throttle Actuator control (TAC) Bank 2.
The car is way too hot for me to even try to check connections, and this code isn't really bringing up much when I do a search. I found 1 or 2 articles about similar issues (minus the red hot glowing cats -- not sure if this is common on this car) where suggestions were to clear the code, unplug the battery for a few hours, turn it back on and do the relearn procedure again, so that's where I am going to start tomorrow along with checking to ensure the connector to the TB is tight. However, I was wondering if anyone has any suggestions or similar problems with installing ported throttle bodies and/or accompanying it with the Soler throttle controller? I'll have to wait until Monday to talk to Tony Mamo or someone at Soler, however the car has been running fine for about 1000 miles with the Soler throttle controller by itself, so I don't know if that has anything to do with this issue I am experiencing, although I guess that combined with the TBs, maybe?
Thanks in advance.
Good luck.
Might want to look into some highflow cats if the cat deletes are the issue. Which cat delete solution did you go with?
if mechanically inclined you can swap the stock tbs back on the eventuri without taking it off takes just a little patience and slide back the coupler there is enough room to get them out. (Four 10mm bolts, one is attached to a bracket)Sometimes w the eventuri the coupler will appear on from the top but be off from the bottom.
As a question nor just for the OP but also others who responded saying they have done these mods as well without issues... as a new C8 Z06 owner I've been reading about people doing similar mods with TB, throttle controller, CAI, cat deletes and also cat back exhaust and it seem like the general consensus is that even all of these together do not add any consistent power to this super high strung engine. I confirmed these results multiple times and there seems to be no evidence that these mods are improving any lap times or 0-60, 1/4 mile or onramp thrills.
Given that seems to be true, can you tell me what you added them for, was it the sound or maybe look of the intakes? What does the cat delete do, more sound? I'm very reluctant to do anything that could void the warranty or damage this incredible Ferrari-like engine, as it already has me shredding track times and canyons like a true supercar and I don't want to spoil that.
The way modern cars make big power with good gas milage and good emissions is through high compression, tight control of A/F mixture and agressive spark timing (ignition advance).
If the ECU doesnt have all of the A/F data or knock sensor data, it goes into limp mode to protect the engine. That includes running a rich A/F mixture, which is much safer than lean (cooler cylinder temperatures), and it retards the timing advance. The retarded timing makes less power, but it decreases the chance of detonation, therefore protecting the engine.
The reason retarded timing makes less power is because instead of getting all of the A/F charge to burn completely during the power stroke, it ignites late and is still burning when the exhaust valves open. This leads to part of the A/F charge burning in the exhaust, rather than in the cylinder. Buring the A/F mixture in the exhaust instead of the cylinder is what led to the glowing red "track section" downpipes.
And since limp mode richens the mixture for engine protection, it means even that much more fuel is burning inside the exhaust pipe.
As suggested above, try disconnecting your wiring harness connector position assurance locks and re-seat them.
Just did another quick search and the Google AI summary of of the same results I found says the gains are 2-4% increase in HP/TQ, I assume like other intakes (ie Rotofab for my LT4) you need a tune to maximize what this and other intakes could do but I'm not ready to void my warranty.
Every video you see where they show 30 hp increase for an intake, the dyno pulls are done on different days, different temps (they put off the dyno pulls until they get a lower DA to optimize their results), they don't tell you that they are running the same batch of fuel or you see some dyno trickery; like the baseline run only goes to 8,200 rpm and the car never reached peak power.
But the videos where they are trying to avoid confirmation bias, do a same day swap and tell you they are running the same fuel, the first dyno runs with the Eventuri intake show lower HP than stock, then as the ECU learns the new intake, the Eventuri eventualy gets back up to stock HP numbers.
I'm guessing you bought an Eventuri intake and are having a hard time accepting evidence that contradicts Eventuri's marketing claims?
First of all, Tony Mamo is awesome. Yesterday was Sunday and Father's day, yet he still called me after he read this post. That level of customer service is not something you're going to get anywhere else in my opinion. So, what I ended up doing:
Since I was getting a code for the throttle actuator on bank 2, I decided to just take them off and swap them in anticipation of the code coming back and moving to bank 1 (if there was an issue with the TB itself). To my surprise (and happiness), after doing the swap and driving around for awhile, the code did NOT come back. I am assuming there had to have been a connector loose or something else, although I am sure I checked them all. I think Phimosis is spot on in his comment here: https://www.corvetteforum.com/forums...#post160971993 and superramvette2 here https://www.corvetteforum.com/forums...post1609718974. There must have been something the car didn't like. I double checked to make sure the Eventuri was properly seated to the TBs as well. I am going out of town tomorrow and Wednesday, so I won't be able to get some more miles on the car until probably the weekend, but this is the farthest I've driven it since the mods were installed without throwing a code. If after a weekend of driving still doesn't come back, I will call this one closed.
To address another comment about whether or not the mods are "worth it" or if there are any real gains from spending $3,000 for the intake, or $900 for the TBs: I did a few 60-130 dragy runs before installing everything. Once I've given the car enough miles to get used to all the new airflow, I will run another few 60-130s on the dragy and let everyone know in this thread if I gained, lost, or maintained the same numbers. One thing to note -- weight savings matters on this car. The stock intake was pretty heavy compared to the Eventuri (I am dumb and was too excited to get started installing it, so I forgot to weigh them). But the weight savings alone from swapping to the titanium cat back, plus eventuri intake, plus cat deletes I would have to say is likely to be at least 100 pounds or more. All of that is not cheap, but the sound and weight savings alone to me is well worth it for this car. Fingers crossed that I see realized gains on the dragy, but even if I don't, I am still happy with the purchases.
