Exhaust smell in cabin when vents on
Old Yesterday | 12:33 AM
RustyDuster's Avatar
RustyDuster
Default Exhaust smell in cabin when vents on
Hi All,
So this weekend I smoke tested my exhaust, and didn't find any leaks. Doesn't mean there arent any, as I haven't been able to get it lifted just yet and inspect closer. It's just that the exhaust smell bothers me and I know that the C4 did not have a cabin air filter.
What are some things I should look for when I do get it up in the air and what are some other reasons the vents could be smelling like exhaust? I never really drive with the top off because it smells.
Thank you all!
Old Yesterday | 12:23 PM
FAUEE's Avatar
FAUEE
What year? Any known modifications? Does it smell from the outside, or through the AC vents?
Blind guess, it's the exhaust manifolds. Good time to invest in headers and a full exhaust. Probably cheaper than paying shops to search for it...
Old Yesterday | 04:28 PM
RustyDuster
Sorry forgot to mention its the 1988 with L98 engine. No modifications (live in CA smog state)
Old Yesterday | 08:08 PM
FAUEE's Avatar
FAUEE
I'm sticking with the manifolds being the issue. Could be as simple as a broken manifold bolt, or could be rust perforation in piping somewhere.
Old Yesterday | 11:05 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Manifold to front y-pipe nuts might not be tight enough or maybe loosened. Although I've never had that happen or seen it happen. There's no donut gasket there on my '90 but not sure on your '88.
I've been getting a rattle noise under my C4 lately. Even when I close the doors.
I got under there and it turned out that the inside of the front Y-pipe is rattling against the outside pipe where it connects to the cat.
I tried tightening the clamp but couldn't get it any tighter to where the inside diameter an outside diameter of the pipes weren't vibrating against each other. Didn't bother pulling out the air tools but at least I know what the problem is for whenever I do feel like messing with it.
That super small space between the two pipes where they connect also throws off an exhaust smell inside the cabin.
Maybe check that kind of thing out if you haven't already.
Of course, FAUEE makes an excellent point, too. Especially about the rust perforation on that front pipe. Could very well be rusty and perforated pipe.
Old Yesterday | 11:10 PM
Natty C's Avatar
Natty C
Yeah, but not in Cali so far as I know. Not if you want to keep it street legal anyway.
I'd like to find some headers with the egr/emissions stuff already welded into them but haven't had any luck. Of course I haven't really looked around too deeply. I cold have sworn I'd seen them around here some place but it may have been a case where the owner fabricated it into them, though.
Here in Delaware, they're equally as **** with that stuff. Maybe even more so. And we also must have mufflers installed by law. I've never failed emissions but I dread having to do it every couple of years.
Old Yesterday | 11:27 PM
merc49's Avatar
merc49
Exhaust leak between the cylinder heads and tailpipe tips. There, I answered it as easily as possible. Air cones into the car via venting on firewall or cowl whichever you prefer, or through the window if it's open. Now you just have to figure out where. I'd start at the exhaust manifolds, next popular place is exhaust pipe connections. If you have the A.I.R. pump and all the associated parts it's another notorious place for exhaust leaks, EGR valve, A I.R. tubes. Find it before you get brain damage from the fumes.
Old Yesterday | 11:48 PM
drive it's Avatar
drive it
Get it up in the air so you can get under it. Then (with engine cold) get a leaf blower, stick in an exhaust pipe and duct tape the other exhaust exits closed and tape the leaf blower in place. Get a bottle of soapy water and start spraying everything. I think you'll be surprised at where and how much it leaks-I sure was!
To Exhaust smell in cabin when vents on
