Fuel Door No Longer Sitting Flush with Body After Fuel Filler Recall Work
It's 2 hours round trip to the dealership, so I'd rather just mess with it myself than bringing it back there.
The problem is there's no adjustability as far as I can tell, there's no adjustable bump stop. The only theory I have is that the fuel filler insert (which is independent of the fuel door) looks ever so slightly pushed in on the right side. And that's the area where the fuel door latches on to lock in place. I tried pulling it out gently with an allen key hooked onto it, but it didn't budge and I didn't want to force it and break anything.
Anyone experience a similar issue and able to get it adjusted?
Did you post this on the Z06 sub forum? If this has happened to others, you are more likely to find them there.
