[C2] wiper switch wiring orientation
Old Yesterday | 07:32 PM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
Default wiper switch wiring orientation
I'm installing the wiring harness in the cluster before installing the harness. Does the orientation of the 2 wire wiper switch connector matter? One side has a light blue and black wire the other wire is black and yellow. The connector will fit on the switch either way. Does the orientation matter?
Old Yesterday | 07:40 PM
acstephenson's Avatar
acstephenson
There should be a tab/lug on the switch to prevent the connector going on the wrong way.
Old Yesterday | 07:45 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
did you take your cluster apart and clean it very well before doing all of this
Old Yesterday | 08:17 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
Many thanks A.Clay! I did not see that tab.
I did not. I looked for some info on taking it apart and cleaning it, but I only saw that folks were sending them out for restoration.
Old Yesterday | 08:51 PM
rccarson's Avatar
rccarson
If you have gone through the trouble to remove the cluster you should give it a good clean up and paint before you re-install it. If you need help give me a pm and I will help you. I'm right up the road from you in Gig Harbor.
RC
To wiper switch wiring orientation
