Door Vapor Barrier
Door Vapor Barrier
I was wondering what to use to hold the plastic vapor barrier on the door. It fits between the door panel and the door. I would like to use something that if I would have to work on anything inside the door at a later date I could get it off without ruining it. Thanks for any info. Chuck
Just get some 3 mil plastic sheeting... duct tape, or silicone it in place...
The sticky roll the fella above me talks about works too... just dont get it on anything!
Originally Posted by Frankenvette
I need to make a vapor barrier. Does anyone sell precut oem replica or are you guys just making one from stuff at Home Depot?
CI 5 & 8 Veteran
Do you even need to replace the vapor barrier plastic if you have aftermarket door panels that have the newer ABS plastic core? The old stock door panels had a cardboard frame back so I can see why it was needed for that.
Bullshark
Bullshark
OMF (02-11-2023)
Vapor Barrier
Use "Monkey Sh t" We used it on everything in the Navy..LOL It's called "Dum Dum on the outside, Walmart calles it Moldable weather caulk...LOL Its just this gray stuff that comes on a roll and its simi hard but moldable.
Originally Posted by '77BABE
I use duct tape
Chucks,
Thanks for the link. That's pretty neat stuff, insulation and moisture proof. I'll have to look into this after a few other projects.
Chucks,
Originally Posted by chucks
He will sell you just the door panel insulation if that's all you want. I think it's about $22.00. I bought some off of him but it's to cold here in Ohio for me to get out in my cold garage and do the work. I'm 62 and just can't work out in a cold garage like I used to. Chuck
I'm 37 and I don't like to work in a cold garage.
Originally Posted by Twin_Turbo
weatherstrip adhesive, the caulk rope gets brittle and catches a lot of sand and seems to come loose after time
Has anyone ever use this product for attaching the vapor barrier to the door?
https://www.homedepot.com/p/Fabral-1...u%3A%7Btape%7D
Thanks.
Steve
Thanks.
Steve
The following 2 users liked this post by Cavu2u:
KENS80V (02-11-2023),
LenWoodruff (07-19-2018)
