■ LS7 Z06 E-Force Build ■
Former Vendor
Customer dropped his car and we are starting on his E-Force project.
First step will be stock baseline – from there the basic steps..
1) Remove Engine
2) Forged Pistons (-8 cc)
3) ARP Rod Bolts
4) Plate Hone
5) Deck
6) Line Hone
7) Balance and reassemble SB
8) SS Valves
9) Comp Valve Job
10) Dual Springs
11) ARP Studs
12) Assemble long block
13) Install back in Z
14) Install E-Force
We will post as it goes along. The results will be interesting as we can push the boost without fear of crumpling the cast pistons.
1) Remove Engine
3) ARP Rod Bolts
4) Plate Hone
5) Deck
6) Line Hone
8) SS Valves
9) Comp Valve Job
10) Dual Springs
11) ARP Studs
14) Install E-Force
Charlie! With the forged pistons what compression ratio will the LS-7 engine now have. It looks like you will be lowering the stock LS-7 compression to compensate for the high boost. Looks like another RPM Motors big HP motor in the making.
1) Remove Engine
3) ARP Rod Bolts
4) Plate Hone
5) Deck
6) Line Hone
8) SS Valves
9) Comp Valve Job
10) Dual Springs
11) ARP Studs
14) Install E-Force
1) Remove Engine
3) ARP Rod Bolts
4) Plate Hone
5) Deck
6) Line Hone
8) SS Valves
9) Comp Valve Job
10) Dual Springs
11) ARP Studs
14) Install E-Force
Just what I want to do Charlie, but then again...You already know that...
Greg
Former Vendor
Former Vendor
Frank,
Keeping it at 10.0:1 and around 10 lbs boost...
Check this chart out. It gives a clear picture of the relationship between static compression ratio and boost pressure and how they equate.
I hope to see it when I pick up my car Charlie.
thanks for taking good care of me.
Steve
Steve
[QUOTE=C_Williams@RPM;1577747878]Frank,
Those numbers should make some big power on a 427ci motor. You must be looking for 850 RWHP with one of your custom tunes and Methanol injected to keep it safe.
[QUOTE=austin@RPM;1577778473]Here are a couple of pics from the machining process in building the motor
Austin! You seem to be expanding your duties at RPM Motors. Besides your duties as shop mechanic it looks like photography was also added to your repertoire of skills.
From what I have seen as a long time customer of RPM Motors, you are a big asset to the shop. I feel I am in good hands having you work on my Corvette.
Former Vendor
