FS TPI/LT1 TRICK FLOW & Professional products throttle bodies
can also be seen on ls1 tech here http://www.ls1tech.com/forums/parts-...le-bodies.html
.lt1/tpi 52mm and 58mm throttle bodies some are brand new and some have very minimal dyno time and have been sitting in garage and
need to make room (all TB's have the upper plate gaskets already installed) I DO NOT HAVE THE lower GASKETS for them unless stated..... they can be bought from summit for very cheap and even ebay for both 52 and 58mm
i have over 10 throttle bodies ONLY all are satin and only one polished most are just the throttle body themselves.
1) lt1 satin 58mm trickflow (92-96 corvette, 93-97 fbody) SOLD
2) lt1 satin 58mm trickflow same years SOLD
3) LT1 Satin 52mm trickflow (92-96 corvett 93-97 fbody) with all hardware and all gaskets 168.00
4)TPI Professional Products 58mm polished (has slight nicks on top of TB plate) 170.00
5)TPI TRICKFLOW 58mm satin with all gaskets 168.00
6) TPI TRICKFLOW 58mm satin 160.00
7) TPI TrickFlow 58MM satin 160.00
8) TPI Professional Products polished 58mm (1985-1992) SOLD
9)TPI Professional Products 58mm polished SOLD
10)TPI trick flow 58mm satin SOLD
11)TPI trick flow 52mm 160.00
12)TPI trick flow 52mm satin 160.00
13)TPI Professional Products 52mm satin 160.00
14)TPI Professional Products 52mm satin 160.00
15)TPI Professional Products 52mm satin SOLD
16) and i have one 58mm TPI professional product one that needs the screw and spring (i missplaced, and you could i believe use the spring and screw) SOLD ****this is the last picture****
retail for 240-280 new
http://www.professional-products.com/throttleLT1.php
looking to ship out on wed and fridays
paypal accepted Mjs1fastss@yahoo.com
a flat rate of 12.00 coast to coast with tracking
send pm if interested in one or
pick up in redlands,ca 92373
can ship usps or pm me your email and where you want it shipped to ill take a few pics of the specific one you want and send it to you from my cell
thanks
thanks
