Southern California Southern California
Passing smog with a Vararam?
Old 11-24-2012, 12:28 PM
Thesisinbold
Thesisinbold's Avatar
Default Passing smog with a Vararam?
Hello all,
I want to put a Vararam CAI on my car. Will it be a problem passing smog here?
thanks
Old 11-24-2012, 03:16 PM
ZEE-OH-6
ZEE-OH-6's Avatar
I believe it does not have a carb # therefore technically it should not pass the visual ?
Actually I don't believe any after market CAI has a carb # to pass a CA smog inspection ........................... ?
Old 11-24-2012, 03:36 PM
Thesisinbold
Okay. I'm not concerned about the visual.
Old 11-24-2012, 08:06 PM
ZEE-OH-6
ZEE-OH-6's Avatar
Never heard of them not passing sniff, but might need a tune if you keep getting lean codes ?
Old 11-24-2012, 08:07 PM
Thesisinbold
Thanks guys!
Old 11-25-2012, 10:59 PM
Dave68
Dave68's Avatar
Don't rely on a "friendly" smog station to get you past the visual. Once they get caught, you may be scrambling to find another and they are getting more scarce by the year. If you want a great CAI that is smog-legal, just get a Callaway Honker and be done with it. I simply swap out my Halltech every 2 years, as it takes no more than 20 minutes to do so.
Old 11-25-2012, 11:20 PM
ZEE-OH-6
ZEE-OH-6's Avatar
.... plus $400.00 every two years for a new one.
Old 11-26-2012, 02:30 AM
hattitude
hattitude's Avatar
Unless you own a 2002-2004 Z06......
The Callaway Honker CARB # excludes the '02-'04 Z06, I found out the hard way....
Just FYI.....
Old 11-26-2012, 01:25 PM
skyavonee
skyavonee's Avatar
Some good info above. If you'll be smogging your car, your best option is to find an intake that has an EO number for your specific year and model (http://www.arb.ca.gov/msprog/aftermk...es/amquery.php).
Second best option is to get one that's easy to remove and replace every two years.
Old 11-26-2012, 09:07 PM
2MFFZo6
2MFFZo6's Avatar
take the vararam sticker off and be done with it.
Old 11-26-2012, 10:18 PM
ZEE-OH-6
ZEE-OH-6's Avatar
do the zip tie mod., cost approx. $5.00 and takes approx. 15 mins. to change back to pass visual inspection - SEARCH the forum for the details if you are not aware of it already ?
Old 11-26-2012, 11:43 PM
skyavonee
skyavonee's Avatar
Old 11-27-2012, 01:24 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Just FYI.....
Did you actually get called out on that by a smog shop? I had the Honker and B&B shorties on my '03 C5Z...and no one ever even noticed them enough to ask about an EO# for either.
Old 11-27-2012, 11:42 PM
hattitude
hattitude's Avatar
No....... I was going to buy it, but then read the Executive Order and discovered it wouldn't work for me. I found out I didn't want to have a non CARB compliant part the hard way.....
I did an engine swap back in the early 80's, before the bi-annual inspections. I went to my first bi-annual inspection, with the bad info that I would be grandfathered in because the swap was before the inspections started. I got caught up with the whole referee, make it compliant regardless of cost, flagged for non-CARB compliance nonsense. I am trying to avoid that nightmare again.
Old 11-30-2012, 07:01 PM
MrMojoRisin921
MrMojoRisin921's Avatar
Old 12-01-2012, 08:49 PM
Dave68
Dave68's Avatar
My Halltech has lasted many years and is still going strong.
Old 12-07-2012, 06:15 PM
mundo
mundo's Avatar
I have an Airaid CAI and just passed smog. No problem. Make sure anything you put on is black. Bright colors like the ricer's CAI intake really draw attention.
To Passing smog with a Vararam?
Old 12-10-2012, 02:00 AM
trance
trance's Avatar
I smogged my vette with the vararam on and totally forgot that it was technically not "legal" the guy didnt even say anything until after I was done paying...
Old 12-10-2012, 11:18 AM
SS MPSTR
SS MPSTR's Avatar
Depends where you go, how knowledgeable the tech is, etc. My Dad's 06 coupe failed visual at a shop in northern California for the VR intake. Brought it down here and it wasn't even noticed, and the car passed with flying colors.
Old 12-17-2012, 11:58 PM
One Nut
One Nut's Avatar
That's what I did and it passed it looks stock from the engine compartment.
Quick Reply: Passing smog with a Vararam?
