Need Zaino detailer on West Side
Hey all
Need a pro to do Zaino/clay detail on two cars - Corvette and Challenger. Preferably on west side of LA.
Who do you guys use or have come to the house?
Thanks in Advance!
Steve
Thanks in Advance!
Steve
I haven't done the Zaino system in quite a while, but it's just takes a some time putting on/off the different coats. No buffer is used, so after claying it, just apply the differing coats. You might try it yourself if you have the time!!
Any other referrals?
Try contacting Ira/Robin at LA Zaino he is the SoCal Zaino Distributor and should know of someone.
Hey Liz, If it's the amount of work have someone else do it, the clay is pretty easy. Just keep it wet inbetween the clay and paint with detail spray or Z?(don't know the Zaino#). Alot like wet sanding. If I say you at a crazy 8's gathering I can show you.
I've been using Ira & Robin for years. They are great people and I have sent them several new customers. I wasn't sure I could recommend them since they aren't vendors on here. I'm glad that you did!
This more of a recommendation versus buying the product. Zaino is a supporting vendor so the distributors should be part of that sponsorship.
Just trying to make sure everyone gets the best of the best
autopia.org is a detailing site with many detailer recommendations there. maybe you can find a zaino detailer there. found one there in OC who does my car now. doesn't use zaino but the stuff he uses is awesome.
You could try contacting Dave at http://www.innovativedetailing.com/ he is probably booked as it is short notice but he does great work and has a mobil set up. He uses many products but not 100% sure about zaino.
Joe
Joe
