Procharger customer service
Follow up. I've purchased and installed many pro chargers on several vets and hotrods that I own. Customer service I got today was insulting. We do not install them we make them. Well you made the dam bov pipe you should know something about if it will fit or have to be altered. Thanks for the past procharger. Car is a 2016 Z.
I'm pretty sure ECS has that figured out. Don't they have the 2200R for Z06 cars? Regardless what I meant was Prochargers response was in poor taste. I like having a shop like ECS there to help and address concerns which they have always done for me. Hope the OP gets it sorted out.
The kit can be made to work but you need to put a std intake on the car and preferably an ati or innovators balancer since the std pulley will not fit the LT4 balancer. Its a costly swap once the intake is added.
Funny thing is Prochargers I take makes less power compared to the stock c7....
At least it looks nice
Edit: I should clarify the above really....
If you're keeping the engine RPM below 7k roughly then hit better off with the stock intake...
Runner length on the factory intake is roughly 10" and the Procharger intake is roughly 6" with a larger CSA too..
I have yet to pull a back to back test, but a friend of mine has and lost tq and hp everywhere...
Makes sense based off manifold design....
If I had an rpm band between 6 to 8k Procharger intake would probably perform better.. But the average 5-7k build on a street setup I would personally choose the factory intake
Not that I've seen.. But I've seen bungs "glued" in for direct port nitrous but I would want something more secure than that..
Seen something cool not long ago.. A TB plate with twin ID850 injectors from ID with a seperate computer to injector fuel
My LT1 Procharger with the smallest unit and 8 psi makes 570 to the wheels. same as a z06. Z06s with prochargers aren't going for low boost. the stock z06 1.7L supercharger caps out at about 750rwhp. People are using prochargers to get into the 900s and beyond.
No.
Chris ecs contacted me and congratulated me on the C7 ..ECS are good guys and know there ****
A@A gave me a 500 discount to use there kit
I felt procharger was correct for my needs..I even get whatever I want from procharger for discounted price..and being sponsored By procharger in the past with my NMCA car felt like its were I need to be...there kit is best in the market MHO
Not sure who u think u are but im not out to wreck someones name like u are hidden behind your PC
Paul Ferrucci
Bad Boy Vettes performance Lead
jealousy is everywere even on CF
Paul Ferrucci
I don't hide behind my PC
Paul Ferrucci
funny little u know
Paul Ferrucci
Paul Ferrucci
Lies... Real Good at Lies...
Your name is like nuclear fallout in the performance industry dude, no one wants anything to do with you. Every issue you had with your C5 you blamed EVERYONE but yourself..
