Questions about OEM ZO6 wheels on an 01 coupe
I have an 01 coupe and I am purchasing some OEM ZO6 wheels and tires. The questions I have are: will my Y2K wheel lug nuts work ok on the ZO6 wheels? and where is the best place to get some ZO6 color lug nut covers? What will my DIC do if I leave the tire pressure sensors on the OEM wheels? Or should I go ahead and install them on the ZO6 wheels? Thanks in advance!
CI 7-8 Veteran
The lug nuts are the same. Not sure which vendor would be best for the lug covers. I spray painted my lug covers black. You could probably find a color to match.
If you do not use the sensors you will have to clear your DIC every time you start the car. Some members have reported problems with not having the sensors.
Your sensors should work with the Z06 wheels. As for the covers just post over in the C5 For Sale/Wanted section and you will get some responses. That's how I got my lug covers for like $20 shipped.
Put the sensors on. They go right on the Z06 wheels. If you do one wheel at a time and put the sensors in the original positon you won't have any problems. I just did this with my 2001 coupe(Z16 wheels). By the way if you have runflats on your 2001 coupe and want to use them on the Z06 wheels they will fit on the new wheels.
