C5/C6 Drop Spindles, Hubs & Lugs! | Prep for the Track with JDP Motorsports
Former Vendor
JDP Motorsports is proud to offer Track prep solutions for your C5/C6 Corvette!
LG Motorsports - Drop Spindles - 1997-2013 C5/C5 Z06/C6/C6 Z06/C6 ZR1 Corvette - 1937
LG Motorsports drop spindles for the 1997-2013 C5/C5 Z06/C6/C6 Z06/C6 ZR1 Corvette features are formed from a solid extruded section of high strength aluminum alloy designed to allow you to lower the ride height of your Corvette 1 full inch over stock while retaining the full shock travel and correct suspension geometry.
Includes set of 4 with hardware.
Product Features
Sale $2,795.95
ORDER HERE
SKF - Performance Wheel Bearing - 1997-2008 C5/C5 Z06/C6/C6 Z06 Corvette - C56SKF
Designed to improve the performance, cornering and stability characteristics that race and super cars demand. The SKF X-Tracker is a performance-engineered hub unit consisting of a double row angular contact ball bearing arrangement in which the outboard row has a larger diameter and contains more ***** than the inboard row. Designed as a direct fit installation, no modification is necessary.
JDP Motorsports also offers new GM fasteners which are required when installation new wheels bearings as the GM bolts are torque to yield. We also offer upgraded wheel studs and lug nuts for performance applications.
Product Features:
Sale $369.95 ea.
ORDER HERE
JDP Motorsports - Racing Stud and Lug Nut Kit - 1997-2013 C5/C5 Z06/C6/C6 Z06/C6 ZR1 Corvette - Part # JDPCH2001
JDP Motorsports racing stud and lug nut kit for the 1997-2013 C5/C5 Z06/C6/C6 Z06/C6 ZR1 Corvette feature 17mm longer than stock and feature a longer tapered bullet nose. These studs are machined from 4340 alloy steel for extra durability and precision. For even longer durability the studs have been phosphate coated grey for a low friction, smooth and reliable lug nut removal.
The lug nuts are machined from 1144 alloy heat treated to 36 Rockwell C steel for extra durability and have also been phosphate coated grey to match the studs. These 19mm lug nuts will make removal easier by allowing a smaller socket to fit between the wheel and the nut.
Product Features:
MSRP: $120.00
Intro Sale Price: $79.95
ORDER HERE
**Note: The racing studs and lug nut kit come in a set of 5 and 4 sets are required per vehicle.
Please feel free to call, PM or email us anytime with questions.
Best regards,
Tyler
888-308-6007
sales@jdpmotorsports.com
Product Features
- 1" lower ride height
- Improved handling
- Lowered center of gravity
- Improved strength for caliper mounts and wheel bearing mount
- Mono ball upper pivot point for improved steering feel
- Improved bump steer geometry
- Full shock travel
- Bolt on install
- Includes Free Shipping to the Lower 48!
Sale $2,795.95
ORDER HERE
Product Features:
- Dramatically increased durability
- Less than 10 micron run-out on flange face
- Improved steering accuracy and dynamic vehicle behavior
- Reduced caliper piston knock-back and braking times
- Black oxide coating for improved corrosion resistance
- Integrated speed sensor for 1997-2008 Corvettes
- Direct fit Installation, no modification is necessary
- Non-symmetrical rows with more ***** at a higher diameter on outboard side
- Free Shipping to the lower 48!
Sale $369.95 ea.
ORDER HERE
Product Features:
- Studs are 4340 alloy steel for extra durability and precision
- 17mm longer than stock and feature a longer tapered bullet nose
- Lug nuts are1144 alloy heat treated to 36 Rockwell C steel for extra durability
- Phosphate coated grey for a low friction, smooth and reliable lug nut removal
- 19mm lug nuts will make removal easier by allowing a smaller socket to fit between the wheel and the nut.
- Made in the USA
- Free Shipping to the lower 48 for orders over $100!
MSRP: $120.00
ORDER HERE
Best regards,
Tyler
888-308-6007
Former Vendor
Thank you for the orders CorvetteForum! Please feel free to call, PM or email us with any questions. Have a great week!
Kind regards,
-Adrian
888.308.6007
Kind regards,
-Adrian
888.308.6007
Former Vendor
Thank you for the orders Corvette Forum! Please feel free to call, PM or email us at anytime with your questions. Have a great weekend!
Kind regards,
-Adrian
888.308.6007
Kind regards,
-Adrian
888.308.6007
Former Vendor
It's still rocking and rolling, come get some.
Best regards,
Antonio
Click HERE to send me a PM Sales@jdpmotorsports.com www.jdpmotorsports.com JDP Facebook 801.545.4215
Best regards,
Antonio
