Paging Tire Rack or others Contis needed
Received 3,043 Likes
St. Jude Donor '05
Price shipped to 91354 Ca
Existing tires
2-265/35/18
2-245/40/18
Basic contis for 4 dr E class nothing special.
pm is fine.
if I went a hair taller on the sidewall where heights were consistent would I need?
245/45/18
265/40/18
2001 E430 sport originally came with 17" Rims has these on now
Will changing height throww off the vss or some goofy electrical issue?
Existing tires
2-265/35/18
2-245/40/18
pm is fine.
245/45/18
265/40/18
Former Vendor
If you look at the front suspension you will find that the spring perch is directly above the tire. The 245/45-18 is 1" taller than the 245/40-18. So, while you can go a little larger than OE you cannot fit a 245/45-18 on your E430
St. Jude Donor '05
so increasing rear sidewall height a hair is out then too
dont like the rubber band tire look, former owner tossed the originals and put these on.
If this is all I can put on whats my shipping to 91354? Site says 99.9999 ea
