Tire Mix and Match on 2011 Gransport
1st Gear
I replaced my front tires March 2016 with Michelin Sport PS2 same as the rear tires.The rears will need replacement shortly. I was thinking of using the Michelin PS A/C 3 plus. Can I keep the fronts PS2 while changing to all-season in the rear? I would change the fronts to all-season when needed.
If all you are doing is going to the grocery store you could get away with it. The general rule is equal traction at all 4 corners. I won't compromise it, my car costs too much along with the safety of my passengers.
budcpa (09-20-2017)
