Can i run 275 / 40 or 35 18's on the back with 275/40 17 in front C5 Z06
Have 03 Z06 with Mint Goodrich Comp Sport 2's on the front in 275/40/17. I need to replace the rears and would like everyhting to match. I know its a little narrow but will the car be ok with 275/40/18 or 275/35/18 on the rear. Will either work and which one would be better. I dont want ABS / TCS issues and i do not want to mismatch tires or scrap the fronts and that is as wide as they make them in 18's
Please help
Please help
Received 1,864 Likes
I recommend you run a 275/40/18 on the rear so the rear sidewalls are the same height, as the fronts. If available, a 285/40/18 would work, too.
