Decrease rolling resistance
Old May 5, 2026 | 04:24 PM
73C34me's Avatar
73C34me
Default Decrease rolling resistance
Hello.
It has been a while since I have been on the site here; cheers.
my 73, with a 4 speed is hard to push (in neutral). With the rear toe in, I realize that increases the effort. Others than tire pressure, has anybody had success in making the car more efficient to "free coast"? It would seem there is some efficiency gains to be had. Thanks
Jim
Old May 5, 2026 | 04:32 PM
AKjeff's Avatar
AKjeff
Parking brake adjustment and synthetic oil in the diff and trans?
Old May 5, 2026 | 05:49 PM
Piersonpie's Avatar
Piersonpie
Making it lighter in general has many benefits. Here’s a thread about it. If you’re looking to just roll it around by hand easier I would get a set of wheel dollies.
Old May 5, 2026 | 06:36 PM
Rebelyell's Avatar
Rebelyell
REM-polished ring & pinion And throughout trans. Ceramic-treated bearings throughout trans & diff & trailing arms.
Old May 6, 2026 | 09:59 AM
pltmgr's Avatar
pltmgr
Front wheel bearing? Brake pad drag? Id jack up each wheel and see how early it rotates.
Old May 6, 2026 | 02:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Got the tires aired up. Couldn't push mine after some time in the garage, tires were low on air.
Old May 8, 2026 | 06:33 PM
LT1M21Vette's Avatar
LT1M21Vette
50 PSI on all four corners.
Old May 8, 2026 | 06:43 PM
wheresmyhorsepower's Avatar
wheresmyhorsepower
Tire pressure and alignment will have the biggest impact.
Assuming everything is in good shape, look into DRP wheel bearing spacers for the front. I just picked up a set to help with a different issue but it's said that they decrease rolling resistance.
Old May 8, 2026 | 11:04 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I have a highly maintained 77. I push mine back and forth frequently in the garage. It's rolls pretty easily actually.
I'm not young. I have cardiovascular disease. And I can roll it.
manual transmission with it in neutral.
I find the easiest way is to push on one of the rear tires in the direction I want to go. If that helps at all.
Old Yesterday | 05:06 PM
MotorHead's Avatar
MotorHead
Methinks he found an air pump and disappeared
To Decrease rolling resistance
