mechanic advised of a leaking front left shock. does this look concerning? if so who soon should I get it replaced? also could this cause the squealing im getting despite replacing my front pads and rotors with powerstops. thanks
I recommend wiping them down and checking again after a few weeks of driving. But at a quick glance, the wetness on the boot looks concerning. Does the car drive OK?
I believe its FINE. Wipe it down and check 500 miles later. These are mag ride shocks and will seep fluid, which is normal and they can last 50,000 miles with that slight seepage.
Shock would NOT cause a squealing but control arm bushings can cause a squeak when moving.
